Homework Helper
- 1,633
No, you specifiedgen x said:If we choose center as B, B is now fixed and everything rotate around B, so how CoM still move in stright line in this anylize?
So there is no change to the motion. We are only changing how we decompose the motion into translation and rotation.gen x said:Frame fixed to the table:
Dale said:I agree. I think we have explained it every way possible. @gen x just needs to actually sit down and do the math.
You are invoking the formula for centripetal acceleration, ##a = \frac{v^2}{r}##, I suppose. That formula does not apply to rotation about a continuously changing point such as the succession of instantaneous centers of rotation.gen x said:So answer from John Alexiou is not correct?
https://physics.stackexchange.com/q...he-bar-rotate-about-the-center-of-mass-or-not
From ground frame velocity at bottom part of car wheel is zero, that mean centripetal force is zero..
In answer are some parts that you(members in my thread) claim are wrong.jbriggs444 said:You are invoking the formula for centripetal acceleration, ##a = \frac{v^2}{r}##, I suppose. That formula does not apply to rotation about a continuously changing point such as the succession of instantaneous centers of rotation.
[I am guessing that the "succession of instantaneous centers of rotation" is the straw man that you are attacking. That is not the only alternative notion of rotation that someone might consider. But it is the one that I will consider in the next paragraph].
If you know the rotation rate and the [motionless by definition] instantaneous center of rotation then you can compute the instantaneous velocities of all the pieces comprising the rigid object in question. But simply knowing those two pieces of information (instantaneous center of rotation and rotation rate) is not sufficient to determine the accelerations of all of those pieces. The trajectory of the sequence of instantaneous centers of rotation would enter into such a calculation.
That is not a substantive response. Since you are not interested in a genuine discussion, I am out.gen x said:In answer are some parts that you(members in my thread) claim are wrong.
Unattributed straw men devoid of context. Not substantive.gen x said:I will qoute them:
"To make the point of rotation the center of mass then there must be zero net force. Any rigid body with a pure torque applied (force couple) is going to rotate, and since the center of mass is not going to translate (zero net force), the center of rotation is the COM."
"Note: By definition the center of rotation is the point on the body (or the extended frame) that does not translate."
You haven't posted the math, that gave you the "wrong result" Are we supposed to guess what you got wrong this time around?gen x said:From ground frame velocity at bottom part of car wheel is zero, that mean centripetal force is zero..
Here must exist centripetal force, why ground frame here show wrong result?
math: Cf=m x 0^2 /r = 0A.T. said:You haven't posted the math, that gave you the "wrong result" Are we supposed to guess what you got wrong this time around?
Yes that is good question. point t1 has centripetal force to the right toward center for frame fixed to center of wheel, but for ground frame centripetal force has different direction.A.T. said:In the ground frame, a point on the wheel circumference is not moving on a circle, so how exactly do you define and compute the centripetal force in the ground frame?
What is "r" supposed to be in the ground frame, where you don't have a circular path?gen x said:math: Cf=m x 0^2 /r = 0
Again, how do you "define centripetal" force in the ground frame? And why do you expect it to have the same value as in the wheel center frame?gen x said:for ground frame centripetal force has different direction.
Let’s simplify that the ruler is a rigid line of length ##L## and mass ##m##. Use the variable ##-L/2 \le l \le L/2## to identify points on the ruler, with ##l=0## being the CoM.gen x said:My assumption is that the desk is frictionless.
After the strike, the center of mass (CoM) of the ruler will move in a straight line because the net force is zero.
I thought maybe " r" of local curvature in specific point.A.T. said:What is "r" supposed to be in the ground frame, where you don't have a circular path?
Doesn’t the centripetal force have to be the same in both reference frames?A.T. said:And why do you expect it to have the same value as in the wheel center frame?
vl(t) =ω⋅lDale said:Now, can you write a function ##v_l(t)## that describes the velocity of the point ##l## in the case that the CoM is stationary and the ruler is rotating with angular velocity ##\omega##?
vl(t)=vDale said:Can you write a function ##v_l(t)## that describes the velocity of the point ##l## in the case that the CoM is moving with velocity ##v## and the ruler is not rotating?
OK, that's just the normal force. But as already said:gen x said:I thought maybe " r" of local curvature in specific point.
A.T. said:... in the ground frame you also have tangential acceleration, because the point is not moving at constant speed.
No, as already said:gen x said:Doesn’t the centripetal force have to be the same in both reference frames?
A.T. said:Only the total acceleration of the point must be the same in both inertial frames.
Why is force frame dependent?A.T. said:No, as already said:
That F is the total force, not just the normal component (perpendicular to velocity).gen x said:F=ma
Excellent, except that you will want those as vectors, not just the magnitudes. So for the rotating $$v_l(t)=(-\omega l \sin(\omega t),\omega l \cos(\omega t))$$and for the translating $$v_l(t)=(0,v)$$gen x said:vl(t) =ω⋅l
vl(t)=v
vl(t)=vtranslation+vrotationDale said:First, write the velocity ##v_l(t)## for a ruler that is both rotating and translating.
Dale said:Second is the difficult step. You need to calculate the position ##s_l(t)=(x_l(t),y_l(t))##
No, as already stated many times:gen x said:isn't only point CoM physically correct
How many times will you ask the same question?A.T. said:- For mere kinematics, any "center of revolution" is as good as another.
- For dynamics, there are choices more convenient than others, but we still have the choice.
A.T. said:No, as already stated many times:
The same in what sense? As already said:gen x said:How can rotation about points A, B and C be the same,
A.T. said:- For dynamics, there are choices more convenient than others, but we still have the choice.
Post a clear description and your math, that you think leads to disagreement with what an accelometer measures?gen x said:acelometer placed on Earth will read different values? Rotation for points B and C must have net force= non zero.
Good! For simplicity and convenience, let’s temporarily choose ##t=0##. At ##t=0## we can use the total ##s## to see that ##y=0##. So now we can eliminate ##l## and express the velocity as a function of ##x## only. Do that for the translational, rotational, and total velocity.gen x said:vl(t)=vtranslation+vrotation
vtranslation=(v,0)
vrotation=(−ωlsin(ωt),ωlcos(ωt))
total velocity of the point at position l:
vl(t)=(v−ωlsin(ωt),ωlcos(ωt))
stranslation=(vt,0)
srotation=(lcos(ωt),lsin(ωt))
total position of the point l at time t:
sl(t)=(vt+lcos(ωt),lsin(ωt)
Dale said:Good! For simplicity and convenience, let’s temporarily choose ##t=0##. At ##t=0## we can use the total ##s## to see that ##y=0##. So now we can eliminate ##l## and express the velocity as a function of ##x## only. Do that for the translational, rotational, and total velocity.
Centripetal force is Fc=mω2rA.T. said:Post a clear description and your math, that you think leads to disagreement with what an accelometer measures?
A.T. said:Don't post a random formula. Post the full math, that shows disagreement with what an accelometer measures.
This acceleration is relative to an non-inertial point B, as opposed to the inertial point A.gen x said:Earth rotate around point B, where x=50 000km:
r=5.0×10^7+6.378×10^6=5.6378×10^7 m
ac=ω^2r.............ac=300m/s^2
No. When you use a non-inertial center of rotation, then you cannot equate relative (coordiante) acceleration with what an accelerometer measures (proper acceleration). You have to account for the proper acceleration of the reference point, which makes the math more complicated. As already said:gen x said:ameasured=9.81−300≈−290 m/s^2
Excellent. Now, notice that ##v(x)=v_{rot}(x)+v_{trans}(x)##. So this decomposition into rotational and translational components does not change ##v##, it just expresses it differently.gen x said:sl(t)=(vt+lcos(ωt),lsin(ωt)) for t=0, cos0=1,sin0=0
sl(0)=(l,0) .... x=l
Translational velocity as a function of x:
vtrans=(v,0)
vtrans(x)=(v,0)
Rotational velocity as a function of x:
vlrot(t)=(−ωlsin(ωt),ωlcos(ωt))
t=0........vlrot(0)=(0,ωl)
l=x.... vrot(x)=(0,ωx)
Total velocity as a function of x:
v(x)=(v,0)+(0,ωx)
v(x)=(v,ωx)
