Refraction through Muliple media
  • Context: Undergrad
  • Thread starter Thread starter sr_philosophy
    Refraction
9 replies · 8K views
sr_philosophy
Consider a ray of light in air traveling towards a medium 1 and then subsequently to a medium 2 and then back to air again undergoes refraction at every pair of media. Let us say that the initial incident angle between air and medium 1 is 'i'. What law states that the emergent ray at then end from medium 2 to air is also 'i'?
Hi sr_philosophy! :wink:
Hint: if the refractive index between air and medium 1 is n1, and between air and medium 2 is n2, what is the refractive index between medium 1 and medium 2? :smile:
no no! if u look back at the history, the formula was derived after they knew that the angles were equal. That is not a hint. Sorry.
Really? How do you know that if you don't know what the formula is? Could you provide a reference?
In any case, the result you require (as well as the more general Snell's law which tim referenced) follows quite trivially from applying the appropriate boundary conditions to Maxwell's equations.
Who told you i didn't know the formula? its not enough if you just know the formula... snell's law applies only for a pair of media... if you didn't know!
Er...you did:
Indeed it does, but as tiny-tim said, you can apply Snell's law here by first applying it when the ray enters medium 2 from medium 1 and then applying it again as the ray leaves medium 2 and enters medium 1.
no! i wish i had a figure to explain things better!
Sorry, I misread your OP. So, you have a ray of light traveling through air, which then enters medium 1, subsequently entering medium 2 and then exiting medium 2 back into the air, yes?
If this is the case, then Snell's law is still applicable, you simply have to apply it three times, once at each interface.
sr_philosophy, are these parallel plane surfaces?
If so, then:
nair sin(θinitial) = n1 sin(θ1)
n1 sin(θ1) = n2 sin(θ2)
n2 sin(θ2) = nair sin(θfinal)
These 3 Snell's Law equations can be combined to show that
θinitial = θfinal
So the answer is Snell's law, plus the geometry theorem (or postulate?) that alternate-interior angles are congruent for a pair of parallel lines cut by a transversal.
Or did I misunderstand what you're describing?
