Regarding quantum physics(fermi energy)
  • Thread starter Thread starter lotrsimp12345
    Energy Quantum
The discussion focuses on deriving the pressure and bulk modulus of an electron gas in terms of internal energy (U) and volume (V) using Fermi energy (EF). The key equations established include U = (3/5)NEF and EF = C V-2/3. Participants clarify that the pressure can be expressed as P = -dU/dV, leading to P = (6/15)NC(V-5/3). The final challenge is to express the bulk modulus B = -V(dp/dV) solely in terms of U, which requires careful substitution and differentiation.
  • Understanding of Fermi energy in quantum physics
  • Knowledge of thermodynamic principles related to pressure and bulk modulus
  • Familiarity with calculus, specifically differentiation
  • Basic concepts of electron gas behavior in physics
  • Study the derivation of pressure in quantum gases using the equation P = -dU/dV
  • Learn about the relationship between Fermi energy and volume in electron gases
  • Explore the concept of bulk modulus and its applications in material science
  • Investigate advanced topics in statistical mechanics related to electron gases
Physics students, researchers in quantum mechanics, and professionals working with materials at the atomic level will benefit from this discussion, particularly those focusing on thermodynamic properties of electron gases.
lotrsimp12345
The average electron energy in an electron gas is known to be <e>=3E(f)/5. The energy for N such electrons would be 3NE(f)/5. Find the pressure in terms of U and V, where V is the volume of the electron gas.
My solution.
Fermi energy
E(f)=(h^2/2m)*((3N/8*pie*V)^(2/3))
therefore E(F) is proportional to V^(-2/3)
since it is proportional i just have to plug into 3NE(f)/5 or the other one correct?
Thanks.
so which formula do i plug V^(-2/3) into E(F)? The 3NE(f)/5 or 3E(f)/5.
Hah, you have me confused. Let's write down what you have:
U=(3/5)NE_F
and
E_F = C V^{-2/3}
where I stuck all those nasty constants that don't depend on V in the term C.
So, you also know P=-dU/dV.
You have all the pieces, just put them together now.
but the pressure needs to be in terms of U and V.
First use substitution to remove the Fermi energy from the first equation. Then take the derivative with respect to V. And substitute back in U to get the pressure in terms of U and V.
thanks.
after i take derivative i have p=-dU/dV=(6/15)NC*(V^(-5/3))
you can't substitue this into U because it isn't=U to derivative of du/dv.
First, 6/15 can be simplified. Second, you can pull a U out of that final equation of yours. Just remember what U is equal to, and factor that out of the equation above, and then make it U.
Can i do this U=3/5*N*C*(V^(-2/3)). so solve for N and plug into p=-dU/dV=(6/15)NC*(V^(-5/3))? don't really understand what you mean by pull out U from -du/dv.
You can do that as well, or even solve for C and plug it in. All the constants will cancel out in the end and you will be left with U and V for your pressure equation.
thank you so much.
now he asks to find bulk modulus. B=-V*(dp/dv) but he wants it in terms on U only and if i take derivative and simplify i am left with 2U/3V again but am unsure of how to get further in terms of plugging in for V.
You need to show some work. And remember that U also depends on V.
so use U=(3/5*N*C*V^(-2/3)) solve for V and substitute?
here's what i did B=-V(dp/dv)=-V((d/dV(2U/3V))=2U/3V. But i need my answer in terms of of only U.
You didn't take the derivative of U with respect to V in that formula. But that formula may not be the best to take the derivative of. Try a formula you quoted earlier...
Take the derivative of that pressure with respect to volume, then substitute the U back in.
Edit: Nevermind, I see your problem. What does the problem ask for exactly?
Problem:
The bulk modulus, B, is defined to be B=-V(dp/dv). Find expression of B in terms of U.
Well, I get a similar answer as with the U/V, except I get a different coefficient than you. But I still also get the volume in my bulk modulus. So not sure how to express it only as U.
thanks for help i will just ask teacher tom.
