Related Rates and acceleration
6 replies · 3K views
Mspike6
I have a question about a related rates, i already solved it, but i would like someone to confirm it to me .
* The relation between distance s and velocity v is given by v=[tex]\frac{150s}{3+s}[/tex]. Find the acceleration in terms of s.
Solution:
[tex]\frac{d}{dt}[/tex] (V) = [tex]\frac{d}{dt}[/tex][[tex]\frac{150s}{3+s}[/tex]][tex]\frac{dv}{dt}[/tex] = 150 [tex]\frac{d}{dt}[/tex] [tex]\frac{s}{3+s}[/tex][tex]\frac{dv}{dt}[/tex] =150 [ [tex]\frac{(3+s)(s') - (s)(s')}{(3+s)^2]}[/tex][tex]\frac{dv}{dt}[/tex] = [tex]\frac{150s'}{(3+s)^2}[/tex]a= [tex]\frac{450v}{(3+s)^2}[/tex]
As you can see my final answer is a in terms of v and s, not s only .. .but am not sure what to do to getrid of this v..
Thanks
There's a mistake between the third and forth lines. Also, what substitution can you make to get rid of v?
thanks, the 4th line should be [tex]\frac{dv}{dt}[/tex]= [tex]\frac{450v}{(3+s)^2}[/tex]
am not sure what sub. get rid of v.
but v' will give me a instead of v, but is that possible, i mean, if i want to get V' i will have to take thderivative for the whole thing.
kreil said:
Your original velocity equation expresses v in terms of s; use that.
sorry but i don't know what you mean .
The Question asked me to find a in terms of s , not v in terms of s
your expression for a is correct, but it contains a 'v'. in order to express a completely in terms of s, you need to use the equation [tex]v=\frac{150s}{3+s}[/tex] and plug this into your equation for a.
Ah, that make sense, thank you :D
