Related Rates - Cylindrical Pools
1 reply · 5K views · last reply
DrummingAtom
2 Cylindrical pools are filled simultaneously at the same rate, 1m3/min. The smaller pool has radius 5m and the water level rises at a rate of 0.5m/min. The larger pool has a radius 8m. How fast is the water level rising in the larger pool?
V = pi(r2)h
I took the derivative of V with respect to h and got:
dV/dt = pi(r2)(dh/dt)
Which dV/dt = 1 and then I just solve for dh/dt. But, if I'm doing this right, the smaller pool should yield the same answer and it doesn't. Because for the smaller pool I would have:
1/pi(52) = dh/dt and this doesn't equal 0.5m3/min.
Thanks for any help.
V = pi(r2)h
I partly agree with you. As stated, the problem doesn't make sense as far as the small pool is concerned. If the pool is being filled at a rate of 1 m^3/min, the rate of change of the water height is 1/(25pi) m/min, which is at odds with the given information.
Where you say that the water in both pools should rise at the same rate, I disagree. Given that both pools are being filled at a rate of 1 m^3/min, the water level in the smaller pool will rise more quickly than it will in the larger pool.
