Related Rates - Differential Equations
Cilabitaon
A ladder, of length 13m, is leaning against a wall. The base of the ladder begins to slide, frictionless, away from the wall; by the time the base is horizontally 12m away from the wall it is moving at a rate of 2ms-1
a)How fast is the top of the ladder sliding down the wall?
b)At what rate is the angle subtended from the ground by the ladder changing by?
Assuming that
[tex]\dot{y} = \frac{dy}{dt}[/tex],
[tex]\dot{x} = \frac{dx}{dt}[/tex],
[tex]y' = \frac{dy}{dx}[/tex]
[tex]y' = \dot{y} \times \dot{x}^{-1}[/tex] (chain rule)
Implicit Differentiation(basic)
Pythagoras' Theorem
First I drew a right angle triangle with the ladder as the hypotenuse and labelled the sides y(the wall) and x(the ground).
Then I get that, when;
[tex]x = 12 , \dot{x} = 2[/tex]
Also;
[tex]y = \sqrt{13^{2} - x^{2}}[/tex]
The next part I did only because I had to use implicit differentiation at some point in this.
[tex]y^{2} = 13^{2} - x^{2}[/tex]
[tex]2yy' = -2x[/tex]
[tex]y' = \frac{-2x}{2y}[/tex]
Now rearrange the chain rule equation to get;
[tex]\dot{y} = y' \times \dot{x}[/tex]
[tex]\dot{y} = \frac{-4x}{2y}[/tex]
[tex]\dot{y} = \frac{-2x}{y}[/tex]
To which I then sub in my values for when x = 12
[tex]\dot{y} = \frac{-2(12)}{({13^{2} - 12^{2})^{\frac{1}{2}}}[/tex]
[tex]\dot{y} = -4.8ms^{-1}[/tex]
I think the first part is right, but I am having trouble with part (b)
I assume it has something to do with
[tex]\tan\Theta = \frac{y}{x}[/tex]
But I can't differentiate that(actually, I can, I just can't seem to get any sensible kind of answer).
All I'm thinking right now is;
[tex]\frac{d}{dx}(\tan\Theta) = -\frac{y}{x^2}[/tex]
Does anybody know if this is the right way to go?
Since you're looking for dθ/dt, try differentiating with respect to t instead of x.
I would, but the point is I have to use the chain rule as many times as I can. The points scored in the exercise are 5 for a correct answer and 2 for either the use of implicit differentiation or the chain rule. This is basic, I know, but we fail if we get less than 16 points.
You get to use the chain rule and implicit differentiation if you differentiate with respect to t.
