Relationship between momentum and kinetic energy in the real world?
The discussion explores the relationship between momentum and kinetic energy, highlighting that kinetic energy is the antiderivative of momentum with respect to velocity. It raises questions about the implications of this relationship, particularly in real-world scenarios and special relativity. The conversation delves into the mathematical derivations, emphasizing that the rate of change of kinetic energy with respect to momentum equals the velocity of the particle. Additionally, it notes that while the kinetic energy can take various forms in the Lagrangian framework, it is specifically quadratic in momentum or velocity within the Hamiltonian approach. The overall conclusion is that understanding this relationship is crucial for applying concepts of work and energy in physics.
nhmllr
I was thinking about the 1/2 in KE = 1/2*m*v2
I thought about how strange it was, and then I realized that as a function on velocity (v), kinetic energy is the antiderivative function of momentum.
However, I am very confused as to what that implies. My question is very vague, but what exactly is the relationship between momentum and kinetic energy in the real world? Is 1/6*m*v3 meaningful?
The energy is the dot product of the velocity and an infinitesimal change in momentum which happens to be
d(\frac{1}{2}mv^2)
The integral just drops the d.
d(\frac{1}{2}mv^2)
The dot product is just the magnitudes of the two vectors multiplied, right?
I still don't understand what the relationship between momentum and kinetic energy really means.
I understand the whole derivative thing with the relationship between distance, velocity, and acceleration. How is this similar?
Just to add another step:
d(\frac{1}{2}mv^2)=vdp=v(mdv)=d(\frac{1}{2}mv^2)
Basically this equation:
\frac{dE}{dp}=\frac{dT}{dp}=v
where T is the kinetic energy.
So the rate at which the energy varies with momentum is the velocity of the particle.
(As an example consider special relativity:
E^2=p^2+m^2
2EdE=2pdp
dE/dp=p/E=v )
So I guess you would take d of both sides
dv=d\frac{dE}{dp}=d\frac{dT}{dp}
Multiply both sides by p and integrate (the RHS by parts):
\int pdv= p\frac{dT}{dp}-T
So I think basically if the kinetic energy is a quadratic function in momentum, then the RHS will be equal to T. To prove this just solve the differential equation:p\frac{dT}{dp}-T=T
dT/T=2dp/p
logT=2*Log[p]
T=p^2
I don't know where the units went (I usually screw up units alot), but if the kinetic energy is quadratic in momentum, then the integral of momentum with respect to velocity will equal the kinetic energy!
Hopefully I didn't screw up somewhere.
Actually, now that I think about it, I think I did screw up somewhere. As an exercise try to find out where!
If you define momentum as p=dT/dv, then it automatically follows that \int pdv=\int dT=T
Anyways, if F*distance=work, and F=dp/dt, and work equals change in energy, then:
F*distance=dp/dt*(vdt)=vdp=dT
That's how you get the expression dT=vdp. This should be completely general.
My views are as follows:
I first regard the kinetic energy is a kind of energy which can show the magnitude of work resulted from the total external force. This definition, to a certain extend, also fits to our intuitions. Then, we may write the formula which may appear frequently in most textbooks:
\int F^{\rightarrow}\cdot d r^{\rightarrow}=\Delta E_k
The left side equals:
\int F^{\rightarrow}\cdot v^{\rightarrow}dt=\int \frac{d p^{\rightarrow}}{dt}\cdot v^{\rightarrow}dt
Then:
\int v^{\rightarrow}\cdot d p^{\rightarrow}=\Delta E_k
So,for a simple 1-D condition:
\frac{dE_k}{dp}=v
This may be the best relation between kinetic energy and momentum.
If the mass can be thought of a constant during motion, this corresponds a low velocity.
If the mass changes with the magnitude of the velocity, in fact, a real condition in our world, this can correspond the formula in special relativity.
OH, sorry, my reply actually repeated the RedX's...
To my surprise!
To my surprise!
That's my fault because I edited my post. I like your explanation better anyhow.
(oh and if you want to put vectors on top of symbols, just use \vec{symbol} )
Anyways, for those of you who know the Lagrangian and Hamiltonian formulation of classical mechanics, I can't figure out where I went wrong. It seems in the Lagrangian approach, the kinetic energy can have any form, and the integral of momentum with respect to velocity should give you kinetic energy.
For the Hamiltonian approach however, the integral of momentum with respect to velocity seems to only give you kinetic energy if the kinetic energy is quadratic in momentum or velocity.
