Relationship Between Surface and Core Temperature of Steel
The discussion revolves around the relationship between the surface temperature and core temperature of 1045 steel during cooling processes. Participants explore methods to estimate internal temperatures based on surface measurements, as well as considerations for thermal expansion when drilling holes for temperature measurement.
  • Experimental/applied
  • One participant suggests that to relate surface and core temperatures, one must consider the original temperature, size, density, heat capacity, and thermal conductivity, and solve a time-dependent heat conduction equation.
  • Another participant reports calculations indicating that the core temperature of a 20" diameter piece would be around 1200°F after 13 hours of cooling from a uniform 2300°F, assuming uniform temperature due to soaking.
  • Questions arise regarding the role of the thermal gradient in determining temperature as a function of surface temperature, with acknowledgment that this is complex and time-dependent.
  • A shift in approach is noted, where one participant plans to drill holes in a scrap piece of stock to insert thermocouples for direct temperature measurement, raising concerns about accounting for thermal expansion during drilling.
  • Another participant contributes that thermal expansion will cause both the outer diameter and inner diameter of the bar to increase, suggesting that drilled holes will not shrink but rather expand with the material.
Participants express varying approaches to estimating core temperatures and the implications of thermal expansion, with no consensus reached on the best method for relating surface and core temperatures or the specifics of thermal expansion effects during drilling.
Participants mention various assumptions, such as uniform temperature and the time-dependent nature of heat transfer, which may affect the accuracy of their calculations and conclusions.
This discussion may be of interest to mechanical engineering students, interns in materials science, and professionals involved in heat treatment processes or temperature measurement techniques in metallurgy.
DrewGerhan
Hey guys,
First off, I apologize if this is in the wrong section. I am currently an intern taking 6 months off from my senior year pursuing a mechanical engineering degree. Having not taken a heat transfer class yet, I am stumped as to how to go about tackling my latest project.
Basically what I need to figure out is how to relate the surface temperature of a piece of stock (1045 steel) that is found using either an IR or contact thermometer to the internal, core, temperature of that same piece. The goal of the project is to be able to take the temperature of the outside of the part, look at a chart and find out the internal temperature and whether or not the part is done cooling.
The biggest piece in question is around 20" diameter and varies down to 8" diameter and will have been in a furnace set at 2300*F with enough time to soak.
Not asking for anyone to do this for me, just help me get started in the right direction.
Thanks in advance,
Drew
One would have to know the original temperature, the size of the heat, density and heat capacity, and some idea of the heat transfer in air, or the thermal conductivity. One solves a time dependent heat conduction equation and may assume that the rate of heat transfer at the surface is more or less constant, and relate that to the thermal gradient.
Astronuc, I think I have gotten to that point. I have attached my work up to this point in the pdf. If my calculations are correct, the core of a 20" diameter piece would be around 1200F after 13 hours if it started at a uniform 2300F.
The original temperature of the part would either be 2300F or 1550F after it comes out of the forging furnace or normalizing furnace respectively. We assume they are uniform temperature as they have have been allowed to soak for 1 hr/in of diameter. I found density to be ρ=7870kg/m3, heat capacity to be 486 J/kg-C and thermal conductivity to be 51.9 W/m-C.
How does the thermal gradient come into play?
I didn't check your exact numbers but BiFo equation is how you should calculate the time.
He mentioned the thermal gradient because you asked how to determine it as a function of surface temperature. However, that is a complicated mess as the dT/dr is a function of time also. Doing it by time is how most in industry do it because it takes so long because of the high heat capacity of the objects they use (as you calculated 13 + hours to cool).
Well we've decided to take another approach to this project. My task now is to drill to holes into a scrap piece of stock to put thermocouples in and directly measure the temperature to get a cooling curve.
My question now is, how do I account for thermal expansion when I drill these holes? Obviously the bar itself will grow in volume when it is heated and therefore the hole diameters will shrink. I'v attached a picture in pdf format to try to show how I plan on setting this up. The stock in this case will be roughly 10" diameter 1045 steel.
Anyone able to shed some light on this for me?
Hey I am also an intern and taking time out of uni so i may not be the most reliable person. But from some work I have done on thermal expansion - your holes will not shrink, they will also increase. So basiclally if you had a steel bar with an extruded hole in the centre, your OD and ID both increase. Think of the thermal expansion as a scale up.
