Relationship between voltage, power and current
The discussion revolves around the relationship between voltage, power, and current in electrical circuits, specifically addressing what happens when voltage is doubled. Participants are exploring the implications of this change within the context of Ohm's Law and basic circuit principles.
  • Participants question the context of the problem, noting the absence of specific circuit details. They discuss how doubling voltage affects current and power, with some suggesting that current is dependent on voltage and resistance. Others raise concerns about the assumptions made in the original question.
The conversation has evolved with participants providing insights into the relationships between voltage, current, and power. Some have offered guidance on how to approach the problem using Ohm's Law, while others have pointed out inconsistencies in the reasoning regarding how these quantities change when voltage is altered. There is an acknowledgment of the complexity involved in the question.
Participants note that the original question lacks a defined circuit setup, which is crucial for accurately addressing the problem. There is also mention of a textbook source for the question, but it does not provide sufficient context or diagrams to clarify the scenario.
Imtiaz Ahmad
Misplaced homework thread moved here by moderator, hence no template.
Hy,
If we double the voltage than what will be double
A. power
B. Current
C. Resistance
D. Both a & b
As usual: It depends. You have not specified the context. A drawing would help.
When we double the voltage in a simple electric circuit, we double the
A. Current
B. Power
C. Resistance
D. Both current and power
you still haven't specified the circuit setup
until you fix (state) a couple of the variables, your Q cannot be answered
Dave
Dave
Actually problem is that
This question is on the textbook which is recommended by government.
So there is not show any circuit
so, so let me provide you with a circuit ...
a nice simple one, a battery and a resistor
do you know Ohm's Law ? ...
a nice simple one a battery and a resistor
Yes I know
Imtiaz Ahmad said:
Yes I know
OK, good
so you have 10V across a 10 Ohm resistor ...
what is the current flowing in that circuit ?
show me your working :smile:
davenn said:
OK, good
1 A
Imtiaz Ahmad said:
1 A
correct
so if you now increase the voltage to 20 V, what is the current in the circuit ?
davenn said:
correct
2 A
Imtiaz Ahmad said:
2 A
correct :smile:
so next, what is the formula for finding power ?
davenn said:
correct [emoji2]
P = I V
P= I (2) R
P = V (2) / R
Imtiaz Ahmad said:
P = I V
P= I (2) R
P = V (2) / R
Yup
for ease we can use your first choice P = I x V
work out the two power levels for the examples we have just done
then answer your original Q ...
Imtiaz Ahmad said:
Hy,
A. power
B. Current
C. Resistance
D. Both a & b
Dave
davenn said:
Yup
Dave
Mean D option is correct
yes, well done :smile:
wasn't too difficult to work out, huh :wink:
Dave
davenn said:
yes, well done [emoji2]
Dave
Thanks
But
Is this answer corrected. If current is double
P = 2 I * 2 V
unlike voltage or resistance, current cannot just change
current is a RESULT of a given voltage across a given resistance
That is, current can ONLY change IF the voltage OR the resistance changes
And the power, in Watts, dissipated in a circuit, in our circuits above ( in the resistor)
is always related to the voltage across the resistance divided by the resistance
so for a fixed resistance, if the voltage is doubled, then the current is doubled and therefore so is the power dissipatedDave
Power dissipated mean?
Mean energy loss
power lost, radiated, used up <---- take your pick, all the same :smile:
[emoji3]
I moved it to homework, where it better fits and can be found by others with similar questions.
Check again the amount by which current and power changed. They don't change by the same factor.
I royally screwed up ... I blame old age and senility :wink: :rolleyes:
@imtiaz ... humble apologies answer b) current ... should have been answer
for power
10V x 1 A = 10 W
double the voltage, the current doubles as correctly stated but the power dissipated quadruples
20V x 2A = 40W
@gneill ... cheersDave
for power
10V x 1 A = 10 W
20V x 2A = 40W
So current is correct
Imtiaz Ahmad said:
Hy,
A. power
B. Current
C. Resistance
D. Both a & b
If circuit is simple
Imtiaz Ahmad said:
Hy,
A. power
B. Current
C. Resistance
D. Both a & b
If circuit is double
