B Relative Mass & Inertia: Could Near-c Collision Destroy a Star?
Chris Miller
If a bullet were to strike the Earth at a velocity close enough to c that its relativistic mass approached that of the Earth, would the damage be equivalent to that of an object of similar invariant mass colliding at a non-relativistic velocity? (The reason I ask is that in Liu Cixin's sci-fi, The Dark Forest, a star is destroyed by hitting it with a small projectile traveling at near c.)
I wouldn't use relativistic mass in this (it's largely a deprecated concept these days outside of pop sci, due to it engendering a lot of confusion), but yes, in theory. The kinetic energy ofa mass moving at speed ##v## is ##(\gamma-1)mc^2##, where ##\gamma =1/\sqrt {1-v^2/c^2}##. That number can be as large as you like, tending to infinity as you approach the speed of light.
Whether or not you can actually destroy a star with a kinetic strike, I don't know. Earth, yes.
Thanks for the clarification, Ibix. Amazing, almost unbelievable, to me that something the size of a BB... a grain of sand... even a neutron? could theoretically destroy the Earth (and why not a star then?) if its velocity were close enough to c. Hope those big particle accelerators have some safety features.
They aren't needed, at least as far as accidentally letting a world-destroying particle loose. The only way of accelerating a particle to world-destroying energies is to supply that much energy to the particle in the first place - the particle never has more energy than what you put into it to accelerate it.
Now, it would be an interesting exercise to calculate the amount of energy required to accelerate a particle to a speed such that its relativistic mass is equal to the mass of the earth... try it.
The only kind of mass I ever talk about is the ordinary mass, so I'll restate your proposal in those terms. A bullet of mass ##0.001## kg collides with Earth, mass ##6 \times 10^{24}## kg. In a frame of reference where Earth is at rest, the bullet is moving so fast that it has an energy of ##6 \times 10^{24}## kg. (Note that I'm measuring energy in kilograms. To convert to joules you would multiply by ##c^2 \approx 9 \times 10^{16}## J/kg.)
Therefore we have ##\gamma \approx \frac{6 \times10^{24}}{0.001} = 6 \times 10^{27}##.
(Note that when a particle's speed is so close to the speed of light that the difference is negligible, we speak of ##\gamma## rather than the speed because the former is more meaningful. This is analogous to speaking of the speed rather than of ##\gamma## when the speed is so small that the difference between ##\gamma## and ##1## is negligible.)
The LHC is the biggest particle accelerator. Its protons move at nearly the speed of light. The ratio of Earth's mass to the proton mass is ##\frac{6 \times10^{24}}{2 \times10^{-27}} \approx 3 \times10^{51}## but those protons are given only enough energy to make ##\gamma \approx 7500##. I think we're safe because we'd need a ##\gamma## of ##3 \times10^{52}## to make that proton as dangerous as your bullet. We have nothing remotely capable of producing that much energy.
SLAC moves electrons at nearly the speed of light and achieves a ##\gamma## of about ##98\ 000##. The ratio of Earth's mass to the electron mass is ##\frac{6 \times10^{24}}{9 \times10^{-31}} \approx 7 \times10^{54}##. Again, we're safe.
Likes SiennaTheGr8
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
