Relative Speed of 2 Beam Lights: Is it C or Zero?
The discussion centers on the relative speed of two beams of light, particularly when they are moving in the same or opposite directions. It explores concepts from special relativity, including the law of velocity addition and the implications of light's speed from different perspectives.
  • One participant questions whether the relative speed of two light beams moving in the same direction is zero or c, citing the law of velocity addition.
  • Another participant argues that light cannot have a "perspective," suggesting that it is impossible to measure the speed of light from the perspective of another light beam.
  • A different participant notes that the velocity addition formula results in an indeterminate form (0/0) when considering two light beams moving in the same direction, indicating a conceptual issue.
  • One participant poses a hypothetical scenario of "riding" a light beam and questions the speed of another beam from that perspective.
  • Responses clarify that one cannot travel at the speed of light unless one is a massless object, and if one were "riding" a light beam, the speed of that beam relative to oneself would be zero.
  • Another participant challenges the initial claim that the relative speed of two light beams moving in opposite directions is c, explaining that the conditions for the velocity addition law do not allow for one frame to have a speed of c relative to another.
Participants express differing views on the relative speed of light beams, with some asserting that it can be c in certain conditions while others argue against this interpretation, leading to an unresolved discussion.
There are limitations in the discussion regarding the assumptions made about the nature of light and the applicability of the velocity addition formula in the context of special relativity.
sayf alawneh
here "c" is the speed of light ,
i have a question in my mind and i have no answer for it ,
if two light beams are moving in opposite directions then their relative speed is simply c using the law of velocities addition in case of special relativity
but what if those two light beams are moving in the same direction will their relative speed be also c or zero
it seems to be zero using the law of velocities addition but my friend claims that it should be c , is that true and how can it be c logically
Are you asking how fast a beam of light travels from the perspective of another beam of light?
The answer is that there is no answer, because light doesn't have a "perspective."
In order to speak of how fast something is traveling relative to an observer, it must be possible (in principle) to measure the speed of that something when you're at rest relative to the observer. But we can never be at rest relative to anything that travels at ##c##. Light simply cannot be an "observer."
Also note that the velocity addition formula yields 0/0 for the relative velocity of two light beams in the same direction, telling you there is a problem.
what if i am riding one of the light beams ?
in other words if i am riding one of the beams that moves in the same direction of another beam what will be the speed of the other beam ?
You can't travel at the speed of light unless you're a massless object , in which case you can only travel at the speed of light.
You can't. If you were "riding a beam of light", then you would be moving at the same speed as that beam of light so its speed relative to you would be zero - but that's impossible because the speed of light is always ##c## for all observers.
No, it isn't. That law relates the speed in one frame to the speed in another, given the relative speeds of the two frames. That relative speed cannot be ##c##. The conditions under which the law is derived forbid it. In other words, if it were indeed possible for one frame to have a speed ##c## relative to another that law wouldn't be valid.
  • · Replies 38 ·
  • · Replies 26 ·
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 51 ·
