Does the Earth's spin impact time dilation for satellites and GPS receivers?
mogsy182
Is it plausable to take into account the speed of the Earth's spin when calculating tmie dilation for satellites and GPS receivers?
You could take into account the satellites spining against the Earth's orbit, with the Earth's orbit and at an angle?
I put it into my project but is it a good idea or am I missing something to do this? I found that for a recevier on the equator and a satellite goin with the orbit the difference to be
9.3 *10^-6 (without relative velocity the answer is 7.3 *10^-6)
can anyone tell me if what I am doing holds for anything?
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
