Relativistic Addition of Velocities
The discussion revolves around calculating the velocities of a probe relative to two starships using the relativistic addition of velocities formula. The probe's velocity is given as -0.895c relative to the Picard, which approaches the starbase at 0.795c, while the La Forge approaches at 0.895c. Participants express confusion about labeling the entities and the correct application of the formula, particularly since it seems to only accommodate three entities despite four being present. Clarification is provided that the velocities are measured from the starbase's frame of reference, and the correct formula for relativistic addition is shared. The conversation emphasizes the importance of correctly applying the formula to find the probe's velocity relative to both the La Forge and the starbase.
ihearyourecho
Faraway Point starbase launches a probe toward the starships approaching from the same direction. The probe has a velocity relative to the Picard of -0.895c. The Picard approaches starbase Faraway Point with a speed of 0.795c, and the La Forge approaches the starbase with a speed of 0.895c.
A) What is the velocity of the probe relative to the La Forge?
B) What is the velocity of the probe relative to Faraway Point starbase?
v23=(v21+v13)/(1+(v21+v13)/c^2)
Okay, this stuff really confuses me. I don't even know how to label them because there are four entities in the problem, but this equation only allows for three. Also, I'm not sure what the velocities of the Picard and the La Forge are relative to (I think to the Faraway Point?) Either way, I need a little help getting on the right path with this then hopefully I can take it from there.
I'm also not that great at the algebra of moving around the equation, but I may be able to handle that.
Your relativistic addition of velocities (I'll call it RAV from now on) formula is incorrect. This is the right one.
<br /> V_{a/c} = \frac{V_{a/b} + V_{b/c}}{1 + (V_{a/b} V_{b/c})/c^2}<br />
The speeds of the starships are given in the starbase's frame of reference. The result of RAV for Picard is given. Work backwards to find the probe's velocity relative to the starbase.
Use this result and another implementation of the RAV to find the velocity of the probe relative to La Forge.
Oh, thanks. I looked at the book too fast (I guess) when I was writing down the equation. It's not that bad at all.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
