Relativistic Energy Derivation math problem
michael154
Hey,
In a derivation of relativistic energy (in Physics for Scientists and Engineers, 5th edition, Serway and Beichner) they use a method of integration by substitution:
Given that
F=\frac{dp}{dt}
and relativistic momentum is given by
p=\frac{mv}{\sqrt(1-(v^2/c^2))}
W=∫F dx=∫\frac{dp}{dt} dx
which is fine then they say
\frac{dp}{dt}=\frac{d}{dt}\frac{mv}{\sqrt(1−(\frac{(v^2)}{c^2}))}=\frac{m\frac{dv}{dt}}{(1−(\frac{v^2}{c^2}))^(\frac{3}{2})}
(This is about halfway through the derivation.)
its that last step that i don't understand. why does the denominator term now have a 3/2 index? and why is du/dt given like that? Any help would be appreciated.
is there a missing square-root symbol?
michael154 said:
\frac{dp}{dt}=\frac{d}{dt}\frac{mv}{1−(\frac{(v^2)}{c^2})}=\frac{m\frac{dv}{dt}}{(1−(\frac{v^2}{c^2}))^(\frac{3}{2})}
(d/dt)(mv(1-v2)-1/2) = m(1-v2)-1/2dv/dt -1/2(-2v)(mv)(1-v2)-3/2)dv/dt
[first term is from d/dt'ing the v in the numerator, second is from d/dt'ing the denominator]
= m(1-v2 + v2)(1-v2)-3/2dv/dt = m(1-v2)-3/2dv/dt
Sorry but that's not very clear. I have trouble reading non formatted math like that. As a second year physics student in uni, should I be able to do that differentiation by hand?
Try looking up "chain rule". Wiki has a definition, it might not be the easiest to read. Note that you want to find (d/dt) p(t) which is equal to (d/dt) p(v(t)), and that m is assumed to be constant (not a function of time).
Sorry I use u instead of v for velocity
In plain English the reason you get an exponent of -3/2 is because γ(u) is an exponent of -1/2, and what's the derivative of x-1/2? It's (-1/2)x-3/2.
I actually just posted a similar question regarding this topic, but with the time component rather than space.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
