Relativistic Harmonic Oscillator Lagrangian and Four Force
The discussion focuses on the Lagrangian formulation of the relativistic harmonic oscillator in an inertial laboratory frame, defined as ##L = -mc\sqrt{\dot x^{\mu} \dot x_{\mu}} - \frac{1}{2} k(\Delta x)^2 \frac{\dot x^{0}}{c}##. Key findings include the canonical momentum components ##\Pi^{0} = \frac{-E}{c}## and ##\Pi^{1} = \gamma {m\dot x}##, with ##\Pi^{0}## being conserved but not qualifying as a four-vector. The Hamiltonian derived from the Legendre transform does not equate to the expected energy, indicating a potential error in the calculations. The four-force is expressed as ##F^{\mu} = -\frac{k\Delta x}{c} \epsilon^{\mu \nu} \dot x_{\nu}##, and the oscillation frequency in the proper time frame is shown to depend on position.
  • Understanding of Lagrangian mechanics
  • Familiarity with relativistic dynamics
  • Knowledge of canonical momentum and four-vectors
  • Experience with Hamiltonian mechanics and Legendre transforms
  • Study the derivation of the Lagrangian for relativistic systems
  • Learn about the properties of four-vectors in relativistic physics
  • Explore Hamiltonian mechanics and its applications in relativistic contexts
  • Investigate the implications of position-dependent angular frequencies in oscillatory systems
Physicists, graduate students in theoretical physics, and researchers working on relativistic dynamics and oscillatory systems will benefit from this discussion.
GL_Black_Hole
Consider an inertial laboratory frame S with coordinates (##\lambda##; ##x##). The Lagrangian for the
relativistic harmonic oscillator in that frame is given by
##L =-mc\sqrt{\dot x^{\mu} \dot x_{\mu}} -\frac {1}{2} k(\Delta x)^2 \frac{\dot x^{0}}{c}## where ##x^0 =c\lambda##, ##x^1 =x##.
a) Find the canonical momentum ##\Pi _{\mu} = \frac{\partial L}{\partial \dot x^{\mu}}## in the lab frame (##t##;##x##). Are any of its components conserved? Is the canonical momentum a four vector?
b) Find the components of the four-momentum ##p^{\mu} = m \frac{d\dot x^{\mu}}{d\tau}##
c) Find the Hamiltonian in the lab frame using a Legendre transform and show that it is conserved in the lab frame. Now are either ##c \Pi^{0}## or ##c p^{0}## conserved?
d) Show that the four force ##F^{\mu}## satisifies ##F^{\mu} =-\frac{k\Delta x}{c} \epsilon^{\mu \nu} \dot x_{\nu} ##
e) Now go to the proper time frame (##\tau##, ##x##) and show that the mass oscillates with a position dependent angular frequency ##\omega (x)##
Note: the proper time frame is NOT the rest frame the mass. It only has clocks which follow along with the proper time of the particle
a) In the lab frame the Lagrangian is ##L= \frac{-mc^2}{\gamma} -\frac{1}{2} k(\Delta x)^2. ## I find that ##\dot x_{0} = -c## so then ##\Pi _{0} = -\frac{1}{c}({-mc^2}{\gamma} -\frac{1}{2} k(\Delta x)^2) =\frac{E}{c}## and ##\Pi_{1} = \gamma {m\dot x}## So the components of ##\Pi^{\mu}## are ##\Pi^{0} = \frac{-E}{c}## and ##\Pi^{1} =\gamma {m\dot x}##. The 0 component is conserved but because the canonical momentum is formed by taking a derivative with respect to non-invariant quantity, coordinate time, it cannot be a four vector.
b) Here I'm not sure if I'm missing something: ##p^{0} = m \frac{d\dot x^{0}}{d\tau} = mc\gamma## because ##\frac{dt}{d\tau} = \gamma## So similarly, ##p^{1} = mv\gamma## where ##v =\frac{dx}{dt}##.
c) I use the canonical momentum here and form ##H =\Pi^{
\mu}\dot x_{\mu} -L## and so ##H = -\frac{1}{c}(\gamma mc^2 + \frac{1}{2} k(\Delta x)^2)(-c) + (\gamma mv)(v) -L## but evaluating this gives me: ##(\gamma +\frac{1}{\gamma})mc^2 + \gamma mv^2 + k(\Delta x)^2 ## which does not equal E as it should.
d) Here I'm not sure what to do and any help would be very much appreciated! e) I know that in the proper time frame ##x^{\mu} = x^{\mu} (\tau)## so ##\frac{dx^{\mu}}{d\tau} = \dot x^{\mu}## and the Lagrangian is ##L= -mc^2 - \frac{1}{2}k(\Delta x)^2 \dot x^{0}##. I find that the canonical momentum ##\Pi_{\mu} = \frac{\partial L}{\partial \dot x^{\mu}} = -mc\gamma \delta_{\mu}^{0}## and so ##p^{\mu} = m \frac{d\dot x^{\mu}}{d\tau} = m \frac{d(-mc\gamma \delta_{\mu}^{0})}{d\tau} = -mk\gamma \Delta x \epsilon^{\mu \nu}\dot x_{\nu}## which is not quite the same as the required result. Thanks in advance for reading this and any help is really appreciated!
  • · Replies 16 ·
  • · Replies 0 ·
