Relativistic quantum theory of interacting particles
242 replies · 57K views
A. Neumaier said:
I presume you mean Theorem 10.2. The problem here is that your e^{i\Phi} does not exist as a unitary operator, so the argument given there and in Section 6.5.6 which you refer to is spurious.
Yes, I work under the naive assumption that if operator [tex]\Phi[/tex] is Hermitian, meaning that [tex]\Phi^{\dag} = \Phi[/tex], then [tex]e^{i\Phi}[/tex] is unitary. This is Lemma F.4 in the Appendix. Could you provide an example, where this assumption is not correct?
A. Neumaier said:
But even if you argue that on the level of perturbation theory, this argument is adequate,
it doesn't change may main point: That for the _calculation_ of radiation corrections to S-matrix entries your formalism is utterly unsuitable, and you need to refer to Weinberg's calculations.
The only reason that does not allow me to perform calculations of radiative corrections with dressed particles is the infrared divergence, i.e., the ill-defined limit [tex]\lambda \to 0[/tex] in chapter 9. As I said earlier, I don't know yet how to overcome this problem. So, your criticism is accepted. However, I also believe that this is a technical problem, which can be solved if some more brain power is applied. As in the standard QED, this problem may be solved by explicit consideration of large (infinite) number of soft photons, which is rather challenging mathematically.
A. Neumaier said:
By the way, in 10.1 you say (p.351 top): ''The physical vacuum in QED is not just an
empty state without particles. It is more like a boiling “soup” of particles,
antiparticles, and photons.'' This is incorrect. It would be a boiling soup of bare particles, but these are eliminated by renormalization. The renormalized vacuum is completely empty and inert.
Agreed. I've changed this piece to read "...boiling “soup” of *bare* particles..." Thank you.
Eugene.
The Hille-Yosida theorem says that e^{i\Phi) exists for a hermitian |phi if and only iff \Phi is self-adjoint.
See, e.g., (2.21) in http://arxiv.org/pdf/quant-ph/9907069 for a non-selfadjoint momentum operator; physically more relevant examples and the HY theorem itself are discussed in Vol.3 of the math physics treatise by Thirring.
Yes. The extra brain power is set free through getting rid of the restricting shackles of Fock space.
It is challenging (since impossible) only when one insists on working in Fock space. Once one allows enough coherent states into the picture (which naturally arise in the field formulation but are orthogonal to all Fock states), the challenge disappears (on the level of rigor of theoretical physics - on the fully rigorous level, additional hurdles arise that are not yet fully overcome).
But bare particles are no particles at all. They become that only if one tries to give the bare fields a particle interpretation - which they cannot have, since all these particles would be infinitely heavy after renormalization. Nobody except popularizers of physics thinks of bare particles as particles.
A. Neumaier said:
But you must convince the world of your logic. They want to see whether there is any advantage in going from standard QED to your version of it. Deriving the Maxwell equations from QED is very standard, while deriving them from your theory seems to impossible without first reconstructing Weinberg's version of it, since when done directly it produces all the strange effects you mention in your book.
A classical e/m field possesses energy and momentum. You won't convince anyone seriously interested in foundations of physics as practiced. maxwell equations are used a lot, thus they must be derivable from any foundation worth its salt. If you not even intend to do that, you give up the claim of having a foundation of electrodynamics. In that case, it is not interesting at all to discuss your theory further.
Let me be clear about it. I believe that Maxwell equations are fundamentally wrong. Yes, their solution can sometimes yield accurate results. But history of science knows many examples when incorrect theories were used successfully for centuries. I agree with your statement that Maxwell equations cannot be derived in my approach, but this doesn't worry me a bit.
Instead of Maxwell equations, I suggest to use the Darwin-Breit Hamiltonian derived in subsection 12.1.1. In chapter 12 I discuss a number of electromagnetic effects and how they can be explained/described using this Hamiltonian. If you know some other effect, where this Hamiltonian fails, then it would be a real problem for my approach. Do you know such an effect?
A. Neumaier said:
I care about the bulk properties, not about the properties of point particles, which don't exist in nature.
If Maxwell equation cannot describe the dynamics of two isolated electrons (I don't care whether you call them point particles or not), then how you can be sure that dynamics of billions of electrons in wires is described correctly?
A. Neumaier said:
Can you derive the anomalous magnetic moment of the electron without recourse to Weinberg? I couldn't find it in you index.
In my approach, the anomalous magnetic moment would appear as a 4th perturbation order correction to the Darwin-Breit potential. I have confessed already that the dressed particle transformation has been performed explicitly only in the 2nd and 3rd orders. The 4th order calculation is complicated by infrared divergences in loop integrals. For example, the relevant vertex renormalization integral in 9.2.6 contains expression [tex]\log(\lambda)[/tex], where [tex]\lambda \to 0[/tex]. The resolution of this divergence is well understood in standard QED. It is related to consideration of soft photons. I hope that a similar solution can be found in the dressed particle approach as well. But I have not done that, and I am not ready to discuss it here.
A. Neumaier said:
But trivial form factors are synonymous with point particles.
I think, we simply used different terminologies. No disagreement on substance. I promise not to call electron and photon point particles anymore. I will call them "elementary particles".
Eugene.
A. Neumaier said:
One cannot go from quarks to hadrons without chiral symmetry breaking, http://en.wikipedia.org/wiki/Chiral_symmetry . And QCD would not be consistent with experiment without instantons, http://arxiv.org/pdf/hep-ph/9610451
As I suspected, these are just theoretical speculations. The symmetry breaking and instantons/solitons have not been observed directly in experiment. Is it true?
Eugene.
A. Neumaier said:
On top of p.133 of your book, I found the remark that ''the photon is not a true elementary particle as it is not described by an irreducible representation of the Poincar´e group. We will see in subsection 5.3.3 that a photon is described by a reducible representation of the Poincar´e group which is a direct sum of two irreducible representations with helicities +1 and -1.''
In your terminology (that only considers irreducible representations of the connected part of the Poincare group), the left-handed photon is elementary, and the right-handed photon is its antiparticle. Thus photons are elementary even according to this rule - just not all of them.
I think this is just a terminological issue. It depends on how we define "elementary particle". I decided to identify elementary particles with irreducible representations of the Poincare group. Since 1-photon space is not irreducible, then, according to my formal definition, photon is not elementary. Another point is that we cannot treat separately right-handed and left-handed photons, because one can always make a linear combination of them, which will defy such classification.
Eugene.
A. Neumaier said:
You'll discover that this sort of hair splitting causes real problems once you try to correctly handle soft photons in your approach. (I tried to find your blog from a few years ago where you had discussed your failure to handle the IR problem, but is seems to have disappeared.)
Try http://meopemuk2.blogspot.com/ This blog was inactive for a few years, but still alive. You are welcome to post your thoughts there.
Eugene.
I am not quite sure that coherent states cannot live in the Fock space. This is sort of like saying that infinity does not belong to the real axis.
I am glad that we fully agree on this point.
Eugene.
Even in case they should be fundamentally wrong, any theory of electrodynamics must explain why they are empirically successful: Not only sometimes but always - except in idealistic situations involving particles that are so small that it is obvious that a classical treatment is no longer adequate. Indeed, so successful that our modern technology would be impossible without it. QED does this without any significant trouble; should yours be an alternative, it would have to do it as well.
How will you convince engineers that they should use your formalism in place of what they are used to and can apply without any troubles?
The former is clearly a matter of quantum physics, not of classical equations, while the latter is an extremely well established empirical fact. And I have given you references to papers that derive this stuff from standard QED.
You don't need to discuss it; but you'll probably get these problems in every computation involving radiative corrections - i.e., in all problems of QED that make the difference between the state of the art in 1930 and in 1948, and that account for the excellent reputation that QED enjoys. Nobody would want to exchange this for a theory where radiative corrections already constitute such a serious difficulty.
I can assure you that an understanding of the work of Faddeev and Kulish would tell you that these problems are intimately related to the fact that your electrons are not the right asymptotic objects, and that you need something more general than a Fock space to start with. Your dressing transformation enforces that your single electron states are also asymptotic states. But they lack the soft photon clouds with which the asymptotic electron states of QED are equipped.
Good. It is always better to conform to accurate terminology - this makes misunderstandings less likely.
Oh yes. Nothing in the standard model beyond QED has been observed directly in experiment. It is all but theoretical speculations. It is highly deplorable that the Nobel price committee gave already a number of their prizes to this sort of speculative physics.
Instead they should give the prize to authors of serious work such as http://lanl.arxiv.org/pdf/physics/0504062 , which promises in its abstract:
''The developed theory is applied to realistic physical objects and processes including the hydrogen atom, the decay law of moving unstable particles, the dynamics of interacting charges, relativistic and quantum gravitational effects. These results force us to take a fresh look at some core issues of modern particle theories, in particular, the Minkowski space-time unification, the role of quantum fields and renormalization, and the alleged impossibility of action-at-a-distance. A new perspective on these issues is suggested. It can help to solve the biggest problem of modern theoretical physics – a consistent unification of relativity and quantum mechanics.''
(In the light of the many practical applications given there, they should excuse the minor difficulty that some of the old speculative computations of the Lamb shift of hydrogen and and the magnetic moment of the electron which agree only to 12 decimal places with experiment could not yet be reproduced.) :smile:
One can also make a linear combination of electron and positron states, or of proton and neutron states. This routinely happens in the applications.
Whereas superpositions of electron and photon states are forbidden by a so-called superselection rule.
No. I'll discuss my thoughts on your work here in this thread. I just wanted to link to some of your entries where you write about the difficulties to handle the IR. But since you talk about these difficulties here, such a link is no longer needed.
Yes, and it doesn't. I haven't seen anyone place infinity somewhere on the real line.
The real line with infinity adjoined is a compact space, whereas the usual real line (without infinity) is noncompact. Also the algebraic properties become quite different. (Of course, if you add many infinities and infinitesimals, you can restore the field property, but then you lose instead completeness, which makes things even worse!)
In a similar way, adding more coherent states to Fock space (some of them live there already, but by far not enough to handle the IR problems!) radically change the properties of the latter.
Thus your analogy is excellent in this respect!
Let me repeat my logic once again. I am concerned about being consistent with experiment. I know that Darwin Hamiltonian explains experiments pretty well (we leave alone radiation at the moment). I've found that my approach reduces to the Darwin Hamiltonian in some approximation. So, I am happy.
Maxwell equations also reduce to the Darwin Hamiltonian in some approximation, and, therefore, also describe experiments pretty well. But this does not mean that it is necessary to prove the equivalence of my approach and Maxwell equations. I know that there are examples involving few interacting particles, where Maxwell's theory yields bad results. These examples include the infinite energy of the electromagnetic field associated with elementary charged particle, violation of the 3rd Newton's law in magnetic interactions, paradoxes of Kislev-Vaidman, Trouton-Noble, "hidden momentum", etc. So, I would prefer to stay away from Maxwell's theory.
As I said earlier, in cases relevant to engineers, Maxwell equations and Darwin Hamiltonian yield the same results. So, I have no problem if engineers continue to use Maxwell equations in their calculations.
Infrared divergences are present in almost all loop integrals of QED. Getting rid of them is not a trivial matter. Yes, you can blame me for not solving this problem within my theory. I am working on it, and believe that it can be done. I am not asking (yet) to replace QED with my approach. I am just saying that there is a non-traditional way to look at QFT. I agree with you that this way has not reached a level of fully developed theory yet. But so far you haven't convinced me that this way is wrong or inconsistent or disagrees with experiment.
Yes, I know Faddeev-Kulish work, but I have a somewhat different understanding of it. Their point is that due to long-range Coulomb interaction, charged particles never move asymptotically. This means that it is wrong to describe their dynamics at large distances by the free Hamiltonian H_0. The assumption of the [tex]\exp(iH_0t)[/tex] asymptotic dynamics is the cornerstone of the S-matrix definition. This means that for charged particles the usual S-matrix cannot be formally defined. The S-matrix plays an important role in my dressed particle approach. I am fitting the dressed particle Hamiltonian to the known form of the S-matrix. If there is no S-matrix, there is no dressed particle Hamiltonian, and my approach does not work.
Kulish and Faddeev suggested a new definition of the S-matrix, which can be applied to charged particles. In this definition, the asymptotic dynamics is described not by H_0, but by H_0 + W, where W is a portion of the full interaction Hamiltonian V, which survives at large distances. The claim is that this new S-matrix can be properly defined. However, there are few issues, which I haven't understood yet.
1. The separation of the asymptotic portion W from the full interaction V cannot be made in a unique fashion. So, I am wondering if this freedom has any effect on the uniqueness of final results.
2. Replacing the asymptotic Hamiltonian H_0 by the new H_0 + W would change completely the perturbation theory. The rules for calculating Feynman diagrams should be different. Kulish-Faddeev didn't spend much time discussing that, and I didn't have enough diligence to repeat all calculations myself.
I read a lot of more recent papers regarding infrared divergences, but I am still not satisfied with my understanding of the issue. I would appreciate if you can recommend a book or review, where all this is explained for pedestrians such as myself.
Eugene.
I've noticed a hint of sarcasm. Or I was mistaken?
We were talking about instantons, solitons, and spontaneous symmetry breaking. I am not an expert in this stuff, but I guess it would be fair to say that these phenomena have not been observed in experiments. They are parts of some theoretical formalisms. The formalisms themselves can be rather successful in explaining/predicting experimental data, but this is not a guarantee that everything inside them have observable counterparts.
Perhaps we should return to this discussion after the Higgs boson is completely rejected by LHC experiments.
Eugene.
I thought that superselection rules forbid forming linear combination of states with different electric charges. So, I wouldn't try a half-electron-half-positron state.
Eugene.
I heard that these kinds of issues are solved within non-standard analysis. I've also heard some people say that this is the only proper way to teach analysis and math in general. But I don't know much about that, so humbly shutting up.
Eugene.
The smiley tells it all.
One could say this for the whole formalism of quantum mechanics, or even of classical mechanics.
Elementary particles are rather successful in explaining/predicting experimental data, but observed are only tracks on photographs, in bubble chambers or wire chambers, moving pointers on instruments, curves and surfaces on screens, etc..
You simply draw the boundary to what is theoretical speculation at the point where your understanding ends. But this is a very subjective and not very constructive position.
I totally agree with that. I was only surprised by your demand that my approach must reproduce instantons, solitons, symmetry breaking and other internal machinery of modern field theories. I don't discard the possibility that a different theory can be proposed, which does not have all these theoretical (unobservable) ingredients, and still describes the experimental world pretty well.
Perhaps even this new theory will be based on particles rather than fields. Knock-knock on wood.
Eugene.
meopemuk said:
Let me repeat my logic once again. I am concerned about being consistent with experiment. [...]So, I am happy.
Maybe your theory is consistent with experiment; this might satisfy you.
But for two reasons it will still be ignored by almost everyone:
The first is that it is so much more difficult to handle than the conceptual toolkit that has been used extremely successfully in the past. Already looking at the explicit QED Hamiltonian to second order in Appendix L is awesome: Everyone will be happy that the terms only comprise three full pages, though the derivation takes 18 tedious pages.
The second is that it does not allow to derive the conceptual toolkit that has been used extremely successfully in the past.
It would be much easier to discount these situations as just theoretical speculations, like symmetry breaking and instantons/solitons - they have not been observed directly in experiment.
But the introductory quotes to your Chapters 9 and 12 come close to that. And your finale on p.568 calls traditional physical theories nuts: ''In this book we critically examined various assumptions and postulates of traditional physical theories (special relativity, Maxwell’s electrodynamics, general relativity, quantum field theory, etc.). We have concluded that many important statements of these theories are either not accurate or not valid''
I am not trying to do that. I am trying to make you apply to your own work the motto you quote in Chapter 14: ''Many things are incomprehensible to us not because our comprehension is weak, but because those things are not within the frames of our comprehension.''
I am trying to teach you
- standards that you need to satisfy in order to get your work recognized, and
- facts about standard quantum field theory that hopefully tells you that the latter is much more powerful than you believe,
- insights that could correct a few deficiencies of your approach that come across as crackpottish, and that makes it impossible to recommend your book to anyone. Your work could be much more commendable if these features - which are not intrinsic to the dressing approach but only to your particular take on it - were absent.
One of your claims in the preface (p.xx) is that ''In modern QFT the problem of ultraviolet infinities is not solved''. This s not the case; the suggestion in Dirac's quote that infinitely large quantities are neglected by renormalization is simply false. What is done is no worse than
replacing the infinity in 1/(1-x) - x/(1-x) for x=1 by the benign expression 1 obtained by properly rearranging the terms before taking the limit. If you can't see that, you are simply not familiar with presentations of QFT that present things in more careful way than what you are accustomed to.
On p. xxi, you claim that ''Our goal here is to demonstrate that all known physics fits nicely
into this mathematical framework.'' From the omission of the maxwell equations, one can conclude that you consider the latter not to be part of the known physics - something almost everybody will find strange.
On p. xxii, you claim that the ''Usual Lorentz transformations of special relativity are thus approximations that neglect the presence of interactions. The Einstein-Minkowski 4-dimensional space-time is an approximate concept as well.'' This is a severe misunderstanding, and nobody will buy that (outside of a theory including gravity).
On p.345 you conclude: ''The existence of instantaneous action-at-a-distance forces implies the real possibility of sending superluminal signals. Then we find ourselves in contradiction with special relativity, where faster-than-light signaling is strictly forbidden''. Rather than have this open your eyes to some misconception in your assumptions (since standard QED does not allow such a conclusion, and you derive your theory from the standard QED interaction), you boldly claim your error to be a failure of all previous approaches - although what you derive is just theoretical speculation. And you top it on p.565 by saying: ''First is the principle of relativity. In spite of widely held beliefs, this principle implies that the concepts of Minkowski spacetime and manifest covariance are not exact and should be avoided in a rigorous theory.''
Write that into the abstract, and everybody will take you for a crackpot. (But some read the summary before the bulk of the work; so your modesty to put this statement at the end will not save you.)
On p. xxii, you claim that ''the rules connecting bare and physical particles are not well established'', although they are fully explained in every textbook on QFT.
On p.566, you claim as a first major advantage of your approach that ''It does not require effective field theory arguments, such as strings or Planck-scale space-time “granularity,” in order to explain ultraviolet divergences and renormalization.'' - This is a strawman argument, since standard QED has the same major advantage!
The second major advantage contains the unfulfilled claim that ''The time evolution, scattering, bound states, etc. can be calculated according to usual Rules of Quantum Mechanics without regularization, renormalization, and other tricks.'' But you were not able to calculate a single scattering cross section involving a loop integral.
The third major advantage is subjective since it depends on what one is prepared to call an observable quantity.
The fourth major advantage that ''The time evolution, scattering, bound states, etc. can be calculated according to usual Rules of Quantum Mechanics without regularization, renormalization, and other tricks'' is also shared by standard QED, together with the CTP formalism (that you never took seriously although i had mentioned it repeatedly). The latter even has the advantage that it is manifestly invariant, while your approach completely sacrifices Lorentz invariance in actual calculations. As a result, all your calculations are much more messy than the corresponding QED calculations.
On p.xxiii you praise your theory that ''All calculations with the RQD Hamiltonian can be done by using standard recipes of quantum mechanics without encountering embarrassing divergences'', although you haven't demonstrated a single calculation involving radiative corrections and are well aware that you run there into embarrassing divergences.
You repeatedly emphasize what you see as shortcomings of standard QED, but you generously overlook discussing the shortcomings of your approach. But every unacknowledged shortcoming discovered by a reader will ruin the reputation of your presentation.
The stuff is somewhat scattered. You might try:
O. Steinmann,
Perturbative quantum electrodynamics and axiomatic field theory,
Springer, Berlin 2000.
but probably this is too mathematical for you. Kulish/Faddeev and Kibble are probably still the easiest treatments on the level of rigor that you are trying to achieve. Perhaps the papers by Lavelle (enter author:Lavelle infrared into http://scholar.google.com ) are helpful, too.
I didn't demand that; I was just pointing out that the QFT description of particles allows for much stuff beyond Fock space, and needs it once you go beyond QED. For QED you also need to go beyond Fock space but in less conspicuous ways. Well, charged states break Lorentz symmetry...
But since your principles change so radically the accepted tenets of tradition (as you explain in your summary), they would have to accommodate also the deeper levels correctly described by the standard model. And it would be extremely surprising if this could be done without all the extra stuff that I had mentioned.
Ah, you touched on an interesting problem, to which I have no answer.
In spite of the charge superselection rule, the Dirac equation for a single electron in an external field (for the relativistic hydrogen atom) treats superpositions of the electron and positron states; though the positron part is ultimately eliminated through a Foldy-Wouthuisen transformation.
On the other hand, nuclear models treat successfully superpositions of protons and neutrons as a nucleon, though these have different charges.
So it seems that the charge superselection rule is perhaps not that fundamental.
Nobody is teaching analysis and math in this ''proper'' way - nonstandard analysis is far too hard. And it lacks compactness, and with it one of the fundamental tools ordinary analysis has.
Although we have a strong research group in our department working on Colombeau algebras (one of the ways of doing nonstandard analysis) nobody ever has managed to apply it to a nontrival problem in quantum mechanics.
Thanks, this is the most important thing for me.
This is just the normal QED Hamiltonian written explicitly in terms of particle a/c operators. Nothing fancy. I don't see any problem with these long formulas. If correct physics requires long expressions, so be it! I agree that it is much easier to work with fields and propagators than in the a/c operator representation. Dressed particle theory is forced to work in this messy representation, because important definitions of phys, unphys, and renorm operators cannot be given in terms of fields.
The difference is that one can, in principle, collide two electrons and monitor their trajectories and measure accelerations at each time point and determine the magnitudes and directions of forces. This is difficult to do, but possible. So, a good theory *must* have a consistent description of such events. On the other hand, no instantons have been prepared in a laboratory. If a theory doesn't know what is instanton - not a big deal.
I agree that this is a bit arrogant. Thanks for drawing my attention. Let me change the last sentence to "We have concluded that many important statements of these theories are not valid in our approach'' Then I go on to list 6 of those questionable "important statements". I would be very much obliged if you can address these specific claims.
Many thanks, indeed!
I didn't want to put too much details in the preface, but since you've mentioned it, I would like to add there one more sentence: ''In modern QFT the problem of ultraviolet infinities is not solved, it is "swept under the rug". The problem is that even if the infinities are "renormalized", one ends up with an ill-defined Hamiltonian, which is not suitable for describing the time evolution of states'' And I stand by this statement. The usual renormalization is not simply a proper definition of limit. Before the limit is taken, one needs to add counterterms to the Hamiltonian, and these counterterms become infinite in the limit. So, we have eliminated divergences in scattering amplitudes at the expense of adding divergences to the Hamiltonian and thus destroying any chances of proper treatment of the time evolution.
Let me change it to a more precise statement ''Our goal here is to demonstrate that observable physics fits nicely into this mathematical framework.'' I take it as a postulate that any exact theory must be (1) quantum and (2) relativistic. This immediately implies that any such theory must be formulated in terms of a unitary representation of the Poincare group in some Hilbert space. Maxwell theory doesn't have this form. Therefore, Maxwell theory is not exact and must be replaced by a more rigorous approach.
This was just a trailer. The full ad can be found in section 11.3. Read it and then see if you want to buy the product.
These introductory statements are supposed to be just appetizers. I suggest you to read the full explanation of these statements in section 11.4 and then form your judgement.
I will wait until you find the time to read the bulk of my arguments. I understand pretty well that this conclusion sounds shocking. I've put it at the end of the book intentionally, so that the reader comes prepared after reading the bulk of the book. You've spoiled my plot by skipping required reading.
I know only one QFT textbook, which devotes significant attention to this issue. This is S. Schweber's book. Still, only model examples are considered there.
Why is it that now 60 years after Tomonaga-Schwinger-Feynman people are still discussing ultraviolet divergences and "effective fields"? I guess many of them are not satisfied with the renormalization solution. Perhaps, because of the ill-defined Hamiltonian, as I've mentioned earlier. The dressed particle approach allows one to have finite scattering amplitudes and a well-defined Hamiltonian at the same time. This has not been done in standard QED.
This is a fair point. I will add there a sentence: "However, the full realization of this program requires solution for the problem of infrared infinities, which remains a challenging mathematical task."
I stand by my claim that unitary time evolution in quantum mechanics requires a well-defined Hermitian Hamiltonian. I don't understand how CTP can do time evolution without a Hamiltonian. I would appreciate very much if you can explain that to me in simple terms.
Thanks. I will change it to ...embarrassing *ultraviolet* divergences...
O. Steinmann,
Thanks. I've tried Kulish/Faddeev and Kibble previously. Maybe I'll be more lucky with Lavelle.
I really appreciate your taking time to read through my book draft and raising your concerns. I see that you've focused on Introduction and Summary so far. Hopefully, we will have even more substantive discussions when you reach the heart of my arguments.
Thanks.
Eugene.
I haven't ventured into the fields of weak and strong nuclear interactions (though I've made one humble attempt in http://arxiv.org/abs/1010.0458 [/URL]). It may well happen that I will find my method not applicable in these cases. Then I will be forced to change my ways. But something tells me not to worry.
Eugene.
I thought that Dirac sea, zitterbewegung, Foldy-Wouthuisen and all that stuff is not taken seriously anymore. Or they are still alive?
Proton charge does not contribute much to nuclear forces. So, it is often ignored in approximate nuclear models. But I think that rigorously we are not allowed to take superposition of a proton and a neutron.
Eugene.
I've read only popular accounts of nonstandard analysis. And I thought to myself that this is exactly what is needed to cure many problems in quantum mechanics and QFT. All these problems with unbounded operators, closed subspaces, domains, convergence, etc, which I hate so much. Unfortunately, my math background is insufficient for that.
Eugene.
It is less difficult than creating an alternative foundation for QED...
You can make a start understanding things by studying the paper mentioned in my post #32.
meopemuk said:
I thought that [...] Foldy-Wouthuisen and all that stuff is not taken seriously anymore. Or they are still alive?
Only the Dirac sea is obsolete. F/W is still needed to understand in quantitative detail bound states of a particle in an external field. Also, more refined versions of the stuff are used in quantum chemistry of heavy atoms, where a relativistic treatment is essential.
Well, it is this sort of things that require one to have an eye at the more general context while developing a special theory. One cannot undo the superpositions of a proton and a neutron by simply adding electromagnetic interactions. But one can renounce the superselection rule.
Thus the likely solution is that Charge is a superselection sector in QED but no longer in the standard model.
No reason to thank - I only said ''perhaps'', in order to make the argument. I believe the basic dressing approach is sound, but the details are not since you misunderstand the nature of a single electron.
This is the reason why you get IR divergences in any loop calculation, while the standard QED approach gets them only in calculations involving external photon lines. Choosing the wrong description of the physical particles makes things worse in your dressing rather than better.
Moreover, your interpretation of relativity is faulty, since you overrate the relevance of the Newton-Wigner representation. it forces the framework into a nonrelativistic mold, and is the source of all the strange effects that you take for real but I had labelled as crackpottery.
They do not occur in Weinberg's setting for QED (on which the CTP formalism is based), from which you start. Since they occur in your version, it can only be because somewhere along the way you made a mistake. The mistake iseems to be either in the wrong features of your electrons, or in your interpretation of Newton-Wigner.
meopemuk said:
TIf correct physics requires long expressions, so be it!
People will compare two formalisms for the same physics, and choose the one that leads to the shortest calculations. The power of a superior mathematical representation has always shaped what was regarded as more fundamental.
I addressed everything in my post. I chose to quote your summarizing statements since that was much easier. But I don't think there is any substance at all in where you deviate from the standard interpretation of relativity.
Good renormalization is nothing but a careful limiting procedure. The precise nature of the limit
is spelled out informally for quantum field theories in Chapter B5 ''Renormalization'' of my theoretical physics FAQ at http://arnold-neumaier.at/physfaq/physics-faq.html#B5 . As a complement, it is spelled out in complete detail for simple quantum mechanical toy models in my paper ''Renormalization without infinities - a tutorial'' http://arnold-neumaier.at/papers/physpapers.html#ren , where I took great pains to avoid even the slightest taint of hand-waving. Reading the latter, you should be able to see why there is nothing at all wrong with proper renormalization, and then you'd be able to see from Chapter B5 in my FAQ that in QFT nothing fundamentally different happens.
You are completely mistaken. Maxwell's theory in vacuum is the theory of the irreducible massless spin 1 representation of the full Poincare group (discrete symmetries included). Thus it is fully identical with the theory of a single photon.
What you write in the preface and the summary is an accurate reflection of what your book contains. I read it a number of years ago. In the mean time, the product hasn't changed, apart from a few cosmetic operations in the advertising. I have every reason not to buy a book that turns serious mistakes into a call for a change of the foundations.
I know, and I formed my judgment accordingly.
I won't read your faulty derivations a second time.
The divergences serve as an introduction to the otherwise incomprehensible need for renormalization. Effective fields have nothing to do with QED, but can be used to show why any low energy theory of the universe must be approximately renormalizable in the classical sense. This is justification enough to discuss these things.
The loop calculations in Chapter 9 are not different from Weinberg or any other QED textbook. Both vertex loop and electron self-energy loop are infrared divergent. See eqs. (11.3.11) and (11.4.14) in Weinberg.
First, Maxwell's theory claims to be something more general than the theory of a single photon. Second, I still insist that *any* relativistic theory must possesses 10 generators of the Poincare group with corresponding commutation relations. Maxwell's theory is not formulated in such a way. So, it violates the most basic requirements of quantum mechanics and relativity.
Thanks for your comments anyway.
Eugene.
