RELATIVITY: Co-ordinates of events
  • Thread starter Thread starter PeterPeter
    Events Relativity
The discussion focuses on the relativistic coordinates of events involving a meter ruler moving at velocity u past a stationary observer. The key equations used are the Lorentz transformations: t2 = gamma*(t2 dash + u * x2 dash / c^2) and x2 = gamma*(x2 dash + u * t2 dash). The correct coordinates for the events are established, with the observer concluding that the ruler's length is L/gamma meters due to length contraction. Participants emphasize the importance of maintaining the time variable t2' in calculations to avoid confusion.
  • Understanding of Lorentz transformations in special relativity
  • Familiarity with the concept of time dilation and length contraction
  • Basic knowledge of the Greek letter gamma (γ) in LaTeX
  • Ability to interpret and manipulate equations in a physics context
  • Study the derivation of Lorentz transformations in special relativity
  • Explore the implications of time dilation and length contraction on moving objects
  • Learn how to effectively use LaTeX for formatting equations
  • Investigate real-world applications of special relativity in modern physics
Physics students, educators, and anyone interested in understanding the principles of special relativity and their mathematical representations.
PeterPeter
A meter ruler moves at velocity u to the right past a stationary observer. The observer is at (0,0) in his rest frame. Give the (x,t) co-ordinates of the following events.
1. The right end of the ruler passes the observer (in the observer's frame)
2. The left end of the ruler passes the observer (in the observer's frame)
3. The observer passes the right end of the ruler (in the ruler's frame)
4. The observer passes the left end of the ruler (in the ruler's frame)
Where the dashed co-ordinates are in the ruler's rest frame.
1. The right end of the ruler passes the observer (in the observer's frame) (0,0)
2. The left end of the ruler passes the observer (in the observer's frame) (0,t2)
3. The observer passes the right end of the ruler (in the ruler's frame) (0,0)
4. The observer passes the left end of the ruler (in the ruler's frame) (-1,t2 dash)
which when I use the above equations I get t2 dash = 1/u
Where have I gone wrong?
PS Not sure how you get subscripts and dashes in LaTex
It would be easier to tell you what goes wrong if you show us how you arrive at your answer.
Regarding the LaTeX part, I have fixed your equations for you:
t_2 = \gamma(u) \left(t'_2 + \frac{u x'_2}{c^2}\right)
x_2 = \gamma(u) (x'_2 + u t'_2)
if you want to know how it was done - quoting this message will show you the code.
Your results for parts 3&4 are correct. You can use the LT to get the results for parts 1 & 2 from the results of parts 3 & 4.
Chet
Chet
Thanks.
I was expecting to get something like length/gamma ie length contraction!
You will, if you do not remove t2' from your equations and instead use the relation t2' = 1/u to break out a factor t2' from your first equation.
I think it would be more instructive to give the ruler an arbitrary rest length L to be honest. That way units in your expression will make sense and you do not fall into the trap of removing t2'.
PeterPeter said:
Thanks.
You would only get that if both ends of the stick are observed at the same time in the unprimed frame.
Chet
I have reworked using a ruler length of L instead of 1m. I get:
2. The left end of the ruler passes the observer (in the observer's frame) (0,L/(u*gamma))
4. The observer passes the left end of the ruler (in the ruler's frame) (-L,L/u)
So the stationary observer would see that the ruler is moving with velocity u and that it takes L/(u*gamma) seconds to pass him.
So I guess he would conclude that the ruler is u*L/(u*gamma) = L/gamma metres long?
PS How does one get the greek letter gamma? I clicked the "Quick symbols" by nothing happened.
Yes, but finding L this way assumes that u is known or measured by the observer. The problem is more well suited to motivate time dilation.
There is a gamma in the quick symbols: γ (between β and δ). If you want the gamma in LaTeX mode: \gamma
As seen in OPs solution, this is not strictly necessary if the velocity u of the object is known. If an object with constant velocity u passes you in time t, you would probably deduce its length as ut and this would be equivalent to using the positions of the end points at the same time in your system.
Thanks. I guess I had a mental lapse, because i had known that previously. "Senior moment."
Chet
Unfortunately, the font used by the quick symbols is awfully inadequate. The symbol for gamma "γ" looks too much like an "y". You can always use the latex "##\gamma##" instead.
Equations are always better in ##\LaTeX## :)
Thanks to you all. I think I'm starting to get the basics of SR!
  • · Replies 32 ·
  • · Replies 34 ·
