Relativistic Time Dilation and Length Contraction in Overtaking Rockets
Rocket A, traveling at 0.800c, overtakes Rocket B, moving at 0.600c, with both rockets being 1000m long in their rest frames. From Rocket B's perspective, Rocket A's length contracts to 0.923l0, and it takes approximately 1.67 * 10^-5 seconds for A to completely pass B. The crew of Rocket A would measure the same time interval due to the symmetry of their situation, as they perceive Rocket B moving at -0.384c and also observe length contraction. The calculations for both rockets yield consistent results, confirming the symmetry argument. Overall, the time taken for the overtaking maneuver is the same from both perspectives.
little neutrino
Two rockets are each 1000m long in their rest frames. Rocket A, traveling at 0.800c relative to the earth, is overtaking Rocket B, which is moving in the same direction at 0.600c.
(i) According to the crew on B, how long does A take to completely pass? I.e. how long is it from the instant the nose of A is at the tail of B until the tail of A is at the nose of B?
(ii) Would the crew of A measure the same time interval according to their clocks? If so, explain why. If not, what is the time interval measured by the crew of A?
l = l0/γ --- Eqn 1
v = (v' + u)/(1 + uv'/c2) --- Eqn 2
(i) Using Eqn 2, A is moving 0.384c relative to B.
Using Eqn 1, length contracted A from B's perspective = 0.923l0
From B's perspective, B is stationary, and A is moving past at 0.384c.
Time taken = (1+0.923)l0/0.384c = 1.67 * 10-5 s
Is this correct?
(ii) I am not sure, but I think the crew would measure the same time interval because of symmetry...??
Thanks!
Your answers to both parts appear to me to be correct (including the symmetry argument). Since you are not confident of (ii), try working it out with the same type of reasoning as (i).
Likes little neutrino
Hmm I thought it would be symmetrical because according to the crew of A, A is stationary and B is moving at -0.384c relative to A. Thus the length of B is contracted to 0.923l0. So time taken for B to pass A is (1+0.923)l0/0.384c = 1.67 * 10-5, which is the same as (i). Is this correct?
Yes. Exactly.
  • · Replies 38 ·
  • · Replies 67 ·
  • · Replies 35 ·
  • · Replies 30 ·
  • · Replies 54 ·
