Removing/creating phase lag or lead in circuit
2 replies · 5K views
edmondng
My square wave is lagging/leading the sine wave (depending how you interpret it). i want to make the transition of my square wave be at 0 deg for the sine wave. right now the square wave transitions at 130 deg of the sine wave
how can i shift this so that it transitions only at 0 deg or 360 deg. is there some things you can do in the circuit?
Thanks
We would need to know the nature of the circuit -- what the waveform generation circuit looks like, and what the load is for each waveform.
one is a sine wave
the other is a square wave.
at the rising edge of sine, i want the square to rise too.
right now, as the square wave rises, the sine wave is at 124deg (ie decreasing)
the load? comes out from an op-amp, just resistors to gnd
between, i generated the sine from a clock oscillator, filter it out to get the sine. any other easier way? I need to generate something around 100kHz and the controller i am using now is not capable of putting out a DAC that will go that fast.
also are there any chips to clean up my square that will put out +- Vout much like a schmitt trigger only capable of putting out -ve Vout
[img=http://img136.imageshack.us/img136/1655/tek00000mg3.th.png]
