Repeated Substitution to solve a recurence.
  • Thread starter Thread starter Kine
    Substitution
The discussion revolves around solving the recurrence relation T(n) = T(n-1) + n^2, with initial condition T(0) = 1. The user attempts repeated substitution but struggles to finalize the solution, recognizing a pattern in the terms. Another participant suggests calculating specific values for T(n) to identify a sequence and fitting a polynomial to it. They recommend using a cubic polynomial, p(x) = ax^3 + bx^2 + cx + d, and solving for coefficients using known values of T(n). The conversation emphasizes the need for a structured approach to derive a closed-form solution from the recurrence.
Kine
I have to solve the following recurrence but I keep getting stuck.
T(n) = 1, n=0
T(n) = T(n-1) + n^2, when n>1
I start by plugging in (n-1) into the function again to get...
T(n)=(T(n-2)+(n-1)^2)+n^2
Which simplifies down to (T(n-2)+2n^2-2n+1.
I then do it again and get this...
T(n)=(T(n-3)+(n-2)^2))+2n^2-2n+1
Which comes out to...
T(n) = T(n-3) + 3n^2 - 6n + 5
By this point I noticed a bit of the pattern and tried to solve the recurrence
T(n) = T(n-k) + kn^2 - (k-1)kn
However, I don't know what to do about the value at the end of the function which more or less halts my progress...
Am I going about this the correct way or am I off base?
So far you have changed from one recurance to another but you haven't "solved" the equation.
If T(0)= 1 then T(1)= T(0)+ 1^2= 1+ 1= 2, T(2)= T(1)+ 2^2= 2+ 4= 6, T(3)= T(2)+ 3^2= 6+ 9= 15, T(4)= T(3)+ 4^2= 15+ 16= 31, T(5)= T(4)+ 5^2= 31+ 25= 56. If you do not recognize that sequence, try fitting a third degree polynomial to it.
Let p(x)= ax^3+ bx^2+ cx+ d.
Taking x= 0, 1, 2, 3 will give 4 linear equations to solve for a, b, c, and d. Check to see if that also workds for x= 4 and x= 5.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
