Determining Resistance of a Copper Wire Without Knowing Its Resistivity
The discussion centers on determining the resistance (R) of a copper wire without knowing its resistivity (ρ). The formula used is R = ρ(l/Σ), where Σ is the cross-sectional area calculated from the wire's diameters. Participants emphasize that while resistivity is typically required, it can be obtained through research if not provided. Dimensional analysis is also highlighted as a method to demonstrate that length alone cannot determine resistance.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the formula R = ρ(l/Σ)
  • Knowledge of dimensional analysis in physics
  • Basic research skills for material properties
  • Research the resistivity of copper and its typical values
  • Learn about dimensional analysis and its applications in physics
  • Explore methods for measuring resistance in practical scenarios
  • Investigate the impact of temperature on the resistivity of materials
Students in physics or engineering courses, educators teaching electrical concepts, and anyone interested in practical applications of resistance and resistivity in materials.
Archimedess
A copper wire has an internal diameter ##d_1## of ##10## ##cm## and an external diameter ##d_2## of 20 ##cm##. If the wire is ##20m## long what is the resistance of the wire?
##R=\rho\frac{l}{\Sigma}##
What i did is: ##R=\rho\frac{l}{\Sigma}=\rho\frac{l}{d_2^2\pi-d_1^2\pi}##
The problem is that I don't have ##\rho##. Is there a way to find ##R## without knowing it?
Many thanks.
Archimedess said:
The problem is that I don't have ρρ\rho. Is there a way to find RRR without knowing it?
If you know the material, you can look it up
This is from a past exam of my course (we can't use any table during exam), a friend of mine says that you don't need it and you can find it anyway.. I doubt it.
Indeed. In real life, problems do not come with all the input data that is required to solve them. In fact, half the work of problem solving (if not more) is identifying the input needed and looking for a way of obtaining this information. In the case of finding the resistivity of Cu, a quick Google search should suffice if you do not have a table of material properties readily at hand (the Google search may be quicker anyway).
You can easily show that quantities of dimension length are not sufficient to determine resistance by using dimensional analysis. Using lengths only it is impossible to build a quantity that has the correct physical dimension.
