Reviewing Kinematics for AP Physics Exams: When to Subtract Gravity?
The discussion revolves around kinematics, specifically in the context of rocket motion and the effects of gravity on acceleration. Participants are exploring when to consider gravitational acceleration in relation to upward acceleration values provided in problems.
  • Participants are attempting to clarify the relationship between upward acceleration and gravitational acceleration, questioning when to subtract gravity from given acceleration values. There are discussions about the implications of net acceleration and the forces acting on the rocket.
The conversation is active, with participants providing insights into the nature of forces acting on the rocket and the concept of net acceleration. Some are seeking clarification on the implications of negative acceleration and how it relates to the rocket's motion.
There is an emphasis on understanding the forces at play, particularly the need to consider both thrust and gravitational forces when analyzing the rocket's motion. Participants are also reflecting on the definitions and implications of acceleration in this context.
belledona
Member advised to use the formatting template for all homework help requests
Hello, I'm reviewing kinematics for an upcoming AP physics exam, but I seem to have forgotten a crucial fact. In typical rocket problems (when the rocket blasts off with an initial acceleration for example 5 m/s^2), why don't we subtract 9.8 from 5m/s^2 when using a value for acceleration? When do we know to subtract gravity from an upwards acceleration, or to just simply use the value given for the upwards accel w/o subtracting?
The 5 m/s2 is the acceleration upwards, and this should become clear from the way the value is given. If you want to find the thrust or forces acting on the rocket, you'll have to take into account that the rocket has to fight against gravity.
The value of 5 m/s2 describes the actual motion of the missile. If gravity is the ONLY force acting on an object, then it will accelerate toward the Earth at 9.8 m/s2.
So when it sits on the launchpad, gravity pulls down with a force, but the ground pushes back with the same exact force, resulting in zero acceleration. When the rocket ignites and exhaust exits the engine, the rocket accelerates upward.
Knowing the actual acceleration of 5 m/s2, can you calculate the amount of thrust necessary to maintain that acceleration? (remember that in F=ma, F is the vector sum of all forces acting on an object).
Oh, so the net acceleration is 5 m/s^2? (As in, the rocket has already overpowered gravity, so 9.8 does not need to be subtracted from 5?)
So the thrust will be F=5*mass of the rocket?
If you were to subtract 9.8 from 5 you would get a negative number. Perhaps get into the habit of thinking about what the answer means. Eg What would a negative acceleration actually mean? Is it likely a rocket taking off would have a negative acceleration?
Let me rephrase that. If acceleration = (net force) / (mass). Net force is vector sum of all forces acting on it. What forces are there and what are the directions?
  • · Replies 38 ·
