Riccati differential equations
The discussion centers on solving the Riccati differential equation given by du/dt = u² + t². Participants explore the transformation u = y'/Ry with R set to -1, leading to the second-order linear differential equation y'' + t⁴y = 0. One participant corrects another's interpretation, clarifying that the correct form is y'' + t²y = 0, which can be solved using power series methods. The conversation emphasizes the importance of accurate substitutions and the application of specific techniques for solving differential equations.
  • Understanding of Riccati differential equations
  • Familiarity with second-order linear differential equations
  • Knowledge of power series solutions
  • Basic calculus and differential equations
  • Study the methods for solving Riccati differential equations
  • Learn about second-order linear differential equations and their solutions
  • Research power series techniques for solving differential equations
  • Explore the properties of parabolic cylinder differential equations
Mathematicians, students of differential equations, and anyone interested in advanced techniques for solving Riccati and linear differential equations.
mcmaster1987
riccati differential equations
how to find general solution of this question
du/dt=u^2+t^2
please say me
i work hard but i do nat know this form of riccati equation. i know when special solution is given however there is no special soltion such that u=u1(t) in this question.
When I make the usual substitution:
u=\frac{y'}{Ry}
with R=-1 in your case (see info about Riccati equation),
I get:
y''+t^4y=0
Suppose you had to come up with an analytic expression for the eqn. in y. What would you do?
u=\frac{y'}{Ry}
I get:
y''+t^4y=0
why do you make u=y'/Ry and why you take R=-1
please tell me.
and i think, you have made an error process.
because you found an equation y''+yt^4=0
but i found y''+yt^2=0. and then i used second order linear differential equation thecniques.
After that i found y=C1e^it+C2e^(-it). i think this is not true.
Thank you for your interest my question.
Ok, my bad. It should be as you said and that's called the parabolic cylinder differential equation:
y''+x^2y=0
But that's not solved using ordinary techniques. You could however, use power series and that's what I was referring to above. Say you get it in the form:
y(x)=\sum_{n=0}^{\infty}a_nx^n
Then the solution to the original DE is:
u(x)=-\frac{\frac{d}{dx} \sum_{n=0}^{\infty}a_nx^n}{\sum_{n=0}^{\infty}a_nx^n}
Nothing wrong with that is there?
