Right Hand Rule & Conventional Current: What is Correct?
The discussion revolves around a problem involving a wire moving in a magnetic field and the resulting charge distribution at its ends. The original poster questions which end of the wire becomes positively charged, referencing Fleming's right hand rule and conventional current definitions.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the application of Fleming's right hand rule and the Lorentz force to determine charge distribution. There is confusion regarding the direction of conventional current versus actual electron flow.
Participants are actively questioning the textbook's explanation and discussing the implications of using different rules. Some have offered clarifications regarding the behavior of electrons and the nature of charge accumulation in the wire.
There is an ongoing debate about the interpretation of charge movement and the definitions of conventional current versus electron flow. Some participants express uncertainty about the correctness of the textbook's answer and the reasoning behind it.
karpmage
I have a question that involves a wire XY (X moving down the page to Y) moving to the right of the page at right angles to a magnetic field that acts out of the paper. The question then asks me which end of the wire will become positively charged. The textbook uses conventional current, and Fleming's right hand rule for induced currents.
2. The attempt at a solution
I know that current will move from X to Y as given by Fleming's right hand rule, and I know that conventional current is defined as being in the direction of positive charge flow (the opposite of the actual electron flow). By this logic, I assume that X will be positively charged. The textbook, however, states that Y will be positively charged.
Is the textbook wrong, or does Fleming's right hand rule give the direction of actual electron flow, rather than the direction of conventional current.
After some looking around, I can see that Fleming's Right-hand rule uses conventional current, but that doesn't explain to me why the textbook got the answer that it did.
Instead of these hand-rules, you can use the expression of Lorentz force for moving charges in magnetic field. It is
## \vec F = q [ \vec v \times \vec B ]##, where q is the charge.
Set up a coordinate system. If the x-axis points outward the page, and the wire moves in the y direction form left to right, the force will be parallel to the z axis (positive z is upward on the plane) . What is the direction of the force on the electrons, up or down? They will move to that end of the wire where the force points, so that end becomes negative.
Hi, According to your answer and the right hand rule related to it-The wikipedia page for Lorentz force says "positively charged particle... will curve perpendicularly to both the instantaneous velocity vector v and the B field according to the right-hand rule (in detail, if the thumb of the right hand points along v and the index finger along B, then the middle finger points along F)."- The force on the electron will downwards, thus Y should be negative, as I thought it would be. Could you just confirm this- I'll attach a picture of the diagram:
Here is proof of the textbook answer:
I just want to make sure that the textbook is wrong because I don't know if I'm just making the same mistake over and over again- even if you guys can't give me a straight answer for whatever reason, I'll probably ask my teacher because I just want to be 100% sure. I just thought I'd try here first, because sometimes my teacher gets confused himself.
"in detail, if the thumb of the right hand points along v and the index finger along B, then the middle finger points along F" is valid for a positive charge. In that case, the force points downward, so Y becomes positive.
You may say that the positive ions in the metal can not migrate. Determine the Lorentz force exerted on the electrons: it is opposite, so it acts upward. The electrons accumulate at the top of the rod, X it becomes negative, Y positive.
If you use the cross product ##\vec F = q [ \vec v \times \vec B ]## with q= -e, ##\vec v = (0, V, 0)##, ##\vec B = (B, 0, 0)## ##\vec F = (0,0,eVB)##. An upward force acts on the electrons.
ehild
Oh I didn't see that the wikipedia article was referring to a positive charge. Thank you very much, I understand now why the electrons accumulate at Y. I'm going to use the Lorentz Force instead of Fleming's right hand rule for this kind of question. I also see now that the magnetic field has made electrons move from Y to X and thus the conventional current will be the opposite of this, from X to Y. Again, thank you so much, you have really helped me.
You are welcome.
ehild
All of this confusion is because you think that the wire XY is the circuit,
So you say that since the electrons flow from Y to X then X must be positively charged and Y is negatively charged, and that's wrong.
Electrons were actually forced to move that way creating a potential difference,
So electrons are FORCED to move to X And they accumulate there under that FORCE so X becomes negatively charged and Y becomes positively charged, if you want a flowing current you must connect X and Y externally making a circuit, then, the electrons will flow from X to Y in the external wire.
You know the fact that electron naturally flow from negative to positive but it needs to be forced to move from
Plaice to negative. Basically, this is analogous to a battery and a circuit, XY is like a battery and the wire that was connected from X to Y externally is the circuit.
Electrons in a circuit flow from the negative pole to the positive pole naturally, but in the battery they are forced to do the opposite they flow from the positive pole to the negative pole.
Same thing with the XY wire, electrons flow naturally from X(negative pole) to Y (positive pole) externally but then they are forced to move from Y to X inside the wire XY.
  • · Replies 16 ·
