Right Triangle and the Pythagorean Triple Formula
5 replies · 2K views
e2m2a
Given: A right triangle and all the sides of the triangle are whole numbers. Does this imply that all the sides of the triangle can only be found by using the Pythagorean triple formula? Another words, is it possible that a right triangle can exist with whole number sides that escape the Pythagorean triple formula? Or put another way, does the Pythagorean triple formula capture every possible right trangle with whole number sides?
Mathematics news on Phys.org
ok. That's what I wanted to know.
This formula does not give all possible triples. It gives all primitives and a bunch of the non primitives, right? If you add the multiples of those then you get all. But then they wouldn't be uniquely expressed (I guess..?).
Would it be relevant to find a formula which generates them all with only two variables..?
Good point. Some multiples are covered, some are not.
(3,4,5) is generated by n=1, m=2, and (8,6,10) is generated by n=1, m=3, but (9,12,15) is not covered as 15 cannot be written as the sum of two squares.
It is trivial to extend the formula to cover all multiples, just add a common factor k to all three lengths. Then you get some triplets with more than one set of integers, but you cover all triplets at least once.
