Disc Rotation: Mass m & Radius r Down Slope of tan^-1 3/4
A disc of mass m and radius r rolls down a slope with an incline of tan^-1(3/4) without slipping. The linear acceleration of the disc is definitively calculated to be 2/5 g. The analysis involves applying Newton's second law and the relationship between linear and angular acceleration, leading to the conclusion that the net force acting on the disc is the component of its weight along the incline minus the frictional force. The equations derived confirm the acceleration value when solved correctly.
  • Understanding of Newton's second law of motion
  • Familiarity with torque and moment of inertia concepts
  • Knowledge of angular and linear acceleration relationships
  • Basic trigonometry, particularly with incline angles
  • Study the derivation of the moment of inertia for a solid disc
  • Learn about the dynamics of rolling motion without slipping
  • Explore the application of torque in rotational dynamics
  • Investigate the effects of friction on rolling objects
Physics students, mechanical engineers, and anyone interested in the dynamics of rolling motion and rotational mechanics will benefit from this discussion.
markosheehan
a disc of mass m and radius r rolls down a slope of incline tan^-1 3/4. the slope is rough enough to prevent slipping. the disc travels from rest a distance of s metres straight down the slope.
(i) show that the linear acceleration of the disc is 2/5 g.
what i did was i first revolved the forces and i got 2 equations
R=4/5 g and 3/5 mg-F=ma but i don't know where to from here
Mathematics news on Phys.org
Okay, if we recognize that the net force $F=Ma_{\text{CM}}$ on the disk parallel to the incline is the component of the disk's weight parallel to the incline less the force of friction $f$ keeping the disk from slipping, we may write (letting $\theta$ be the angle of the incline above the horizontal):
$$Mg\sin(\theta)-f=Ma_{\text{CM}}$$
The force of friction results in a torque about the center of mass, having a lever arm $R$, so we may write (where $I$ is the moment of inertia for the disk):
$$\tau=Rf=I\alpha$$
Solving for $f$, there results:
$$f=\frac{I\alpha}{R}$$
And so we now have:
$$Mg\sin(\theta)-\frac{I\alpha}{R}=Ma_{\text{CM}}$$
Now, we may relate the angular acceleration $\alpha$ of the disk to its linear acceleration$a$ as follows:
$$a=R\alpha$$
Since the disk rolls without slipping, we know:
$$a=a_{\text{CM}}$$
Hence:
$$\alpha=\frac{a_{\text{CM}}}{R}$$
And now we have:
$$Mg\sin(\theta)-\frac{I\dfrac{a_{\text{CM}}}{R}}{R}=Ma_{\text{CM}}$$
Or:
$$Mg\sin(\theta)-\frac{Ia_{\text{CM}}}{R^2}=Ma_{\text{CM}}$$
So, what do you get when you solve for $a_{\text{CM}}$?
i get 2/5 g when i solve for a but i don't get your full solution. what is the formula of a disc for angular acceleration what does a=Ra stand for.
For a rolling object (circular such as a cylinder, sphere, disk, hoop, etc.) of radius $R$, the linear acceleration $a$ and the angular acceleration $\alpha$ are related as follows:
$$a=R\alpha$$
  • · Replies 18 ·
