RLC circuit with initial conditions at t=0
36 replies · 5K views
Arman777
Insights Author
I used the loop rule where ##ΣΔV=0## and junction rule.
From here I get 4 equations
##i_3=i_1+i_2##
##ε-i_3R_3-i_1R_1-L(di\dt)=0##
##ε-i_3R_3-i_2R_2-Q\C=0##
##i_1R_1-L(di\dt)+Q\C+i_2R_2=0##
1-I said Q\C will disappear since Q=0 at t=0. But what about (di\dt) ? Is (di\dt)=0 ? I think it should be, but If its zero I didnt understand why it asked again since we need to claim its zero to solve the question.If its not zero then I couldn't solve the upper 4 equations.İts like something is missing.
You do not need any equations here.
Just apply what you know about the behaviour of L and C at the moment of energization i.e. t=0.
What is the current through the inductor "just before" the switch is closed?
What is the current through the inductor "just before" switch is closed?
Isnt it a time depented value ? Function like I(t)=Awcos(wt)+Bwsin(wt) ? I don't know...
Yes.
But you only need to know what happens at t=0.
cnh1995 said:
Yes.
Can you help a bit more..I couldn't see the solution
There was no source in the circuit before the switch is closed.
So what can you say about the inductor current "before" the switch is closed?
Arman777 said:
Zero ?
Yes. So what is the inductor current just after closing the switch?
You could have just say yes.. ? Are my equations wrong ? Cause I need to find currents.
I just answered your question. You need to be more specific about your problems.
Only at t=0. As I said, you do not need any of the equations you've written.
What can you say about the current through the capacitor at t=0 i.e. just after the switch is closed?
Ok. I think you do need to solve the equations for solving b and c because of presence of R1. The current through R1 is governed by both L and C values. My apologies.
But you do not need them to know i1 and i2 at t=0.
Arman777 said:
Question asks that,I need to know
Yes. So what is the current through the capacitor at t=0?
How does a capacitor behave when energized at t=0?
##i_3=i_1+i_2##
The fourth equation is not needed. And di/dt should be di1/dt.
So you have the system of equations
##i_3=i_1+i_2##
##ε-i_3R_3-i_1R_1-L(di_1/dt)=0##
##ε-i_3R_3-i_2R_2-Q/C=0##
Substitute ##i_3=i_1+i_2## for i3. You might need the relation between Q and i2. Then you have a system of equations for two currents and their derivatives.
The problem asks the initial values. You found that i1(0)=0. What about i2(0)? Answer @cnh1995's question.
Zero ? At the beginning there should be no current ? Seems wrong but also makes sense.
##i_3=i_1+i_2##
I see well I find ##-i_2R_2=Q\C## but in any case at t=0,Q=0
Yes but for t>0 you should get something else
Rest of the question.Well at ##t=∞## there would be no current on the capacitor brench.
In the brench where inductor exist, there would be current.I can write an equation like, ##ε-iR_3-iR_1-L(di\dt)=0##.Do I need to solve this ? I couldn't directly see the answer.
For (e) probably its ##εC##.
For (f), I need to find that current passes through inductor,I know the equations and ıf my answer to e is true then I can find it easily.
No, it is not true . You ignored i3, and it is not zero at t=0.
Arman777 said:
can write an equation like, ##\varepsilon-iR_3-iR_1-L(di/dt)=0##. Do I need to solve this ? I couldn't directly see the answer
Yes, no and Oh? :smile: What do you expect of the ##dI/dt## in the last term ?
(e) No. draw the circuit a little differently: ##\varepsilon## on the left and all the R etc on the right
(f) What you say is true...
Shame on me o:). Wake up first and then check PF. Over to you, Ersbeth
Arman777 said:
I didnt understand...I ll ask my proffesor I guess...
Substitute I3=I1+I2 into your second and third equations. What do you get?
Use that i1=0 and Q=0 at t=0 in the second equation. What is i2 at t=0?
Knowing i2(0) and i1(0) you get d(i1)/dt from the first equation.
I find ##i_2=2A## and ##di_1\dt=6A\s##
Correct, but use / in fractions, instead of \.
an oblique stroke (/) in print or writing, used between alternatives (e.g., and/or ), in fractions (e.g., 3/4 ), in ratios (e.g., miles/day ), or between separate elements of a text.
So ##di_1/dt=6A/s##.
Now take the derivative of the second equation, and use that i2=dQ/dt. Calculate di2/dt.
Arman777 said:
Why do we need this ? .I ll do that in a moment
Oh, well, it was not asked.
Then go to the questions about infinite time. What are i1 and i2?
Well ##i_2=0## since capacitor is full.There can't be current.I couldn't find ##i_1##...I think its 1A but I am ot sure...I thought ##ε=i_1(R_1+R_3)+L(di_1/dt)##
Part (e) I guess Q=εC
Part (f) If its one ampere and I find charge correctly then ##U_L=1/2Li^2## and ##U_C=Q^2/2C##
