Rms current, complex area, phasors
10 replies · 5K views · last reply
Bassalisk
why is RMS voltage used in euler complex system, and not max voltage
You can represent any sinusoid in terms of phasors regardless if it's RMS or not.
We usually use rms voltage because this is what's important in power consumptions considerations and such.
For example, we say that the voltage of a common power outlet is 120 V which is its rms value. This allows easy calculations of power consumption because an ac voltage of 120 V rms will have the same effect on a 1 ohm resistor than 120 V dc.
U didn't get what I asked. I am asking, why didn't we extract MAX voltage from original formulas(sinusoid) but we divided it by square root of 2, and then threw it into euler's formula?
You could have kept the max voltage throughout. It's just that they convert it to rms value from the beginning because that's what is used in real life applications. Keeping the max value (amplitude) instead of rms value would do no harm to the equations. It's just that at the end you'd have ended up with the max values which are less relevant.
Thats it? Pff i was hoping for "aha" moment. Thanks!
But this RMS, why do we have that anyway? I mean if I apply 100 volts of AC, why do i get only 0,707 of that, and why that specific ratio?
The RMS value is defined as:
Formula for the RMS value: f_rms equals the limit as T goes to infinity of the square root of (1/2T times the integral from -T to T of [f(t)] squared dt).
What that means is that you are averaging voltage squared of a periodic function over a time interval, and then taking a square root to get the average. If you calculate RMS for a sine wave, you will end up with 0.707 factor. But for a triangle wave or a square wave or another complicated wave, RMS will be different.
I always teach kids to use RMS when you're dealing with power because then its P=VI* instead of P=1/2 VI*
