Rockets and inverted pendulums
  • Context: Undergrad
  • Thread starter Thread starter CyberneticsInside
    Rocket Rockets
The discussion clarifies the mechanics of rocket stability, particularly in relation to the positioning of thrusters and the role of control systems. It establishes that rockets with fixed motors are inherently unstable, and stability is achieved through adjustable thrust vectors, often regulated by advanced control systems rather than simple PID controllers. The conversation also highlights the misconception of comparing rockets to inverted pendulums, emphasizing that the torque dynamics differ significantly. Notably, the X-15 is mentioned as a successful example of a rocket utilizing control surfaces for stability.
  • Understanding of rocket propulsion mechanics
  • Familiarity with control systems, specifically PID and higher-order filters
  • Knowledge of aerodynamics and the role of center of mass and center of pressure
  • Basic principles of stability in dynamic systems
  • Research advanced control systems for rockets, focusing on vector thrust techniques
  • Study the dynamics of inverted pendulums versus rockets with fixed and movable thrusters
  • Explore the design and functionality of the X-15 rocket and its control surfaces
  • Investigate the effects of air resistance on rocket stability during launch
Aerospace engineers, rocket scientists, students of physics, and anyone interested in the principles of rocket stability and control systems.
CyberneticsInside
Hi, I can´t understand how a rocket is not flipped over by the thrusters (especially without finns). I know this is a general misconception of how a rocket works, but it seams intuitive that it would behave like a inverted pendulum, since the force works below the center of mass, of the rocket.
Does someone have a dumbed down explanation?
The rocket motors can be turned some degrees. Hence the rocket can be balanced, giving the lower end of the rocket some horizontal force.
Have a look at this video:
After about 1:42 min., you can see the motors turn slightly.
Ok, thanks for the response.
So the stability is caused på some kind regulator, f. instance a PID? Meaning a fixed motor will be un-stable?
I don't think the term "PID" ( first order filter ) can be used. I think that a system of higher order filters are used for the purpose.
Yes, with a fixed motor, the rocket will be unstable.
oh i see, thank you.
But at sea level, a rocket may be stabilized with finns on the body? (Fixed motor)
Several types of aircraft have been built with rocket engines - mostly for research purposes . These had control surfaces .
One of the most successful was the X15 .
https://en.wikipedia.org/wiki/North_American_X-15
A rocket, that is launched at sea level, has no speed. Thus wings/finns will not work. But a missile flying horizontally at sea level at high speed may be stabilized by means of wings/finns.
New year rockets are stable with a "fixed motor", because the motor is placed at the top og the rocket. ( Front wheel drive ).
I don´t follow when you say rockets at sea level has no speed. What do you mean ?
And I believed that the center of pressure is further to the ground than the center of mass, in new years rocket.
I saw an old picture of a ¨Front wheel´´ driven rocket, but it was highly unstable, and crashed shortly after launch. Should think a rocket like that, would be stable.
http://history.info/wp-content/uploads/2015/03/Modern-rocket.jpg
Well, I assume that the rocket is not launched submerged, and if the astronauts are to be accelerated by say 5g, it will take some time before the rocket has achieved a speed whereby it can be controlled by wings/finns.
Well, it has this rod at its tail. Try to remove/shorten the rod next new year, and test the result.
( Keep distance )
Oh yeah. I did not think of the rod. Sounds interesting to try tough (remive the rod)
It is not interesting, it is dangerous.
The rocket will be completely out of control.
Yeah, obviously :p
All the more reason to applaud the early rocket pioneers who made rockets work without the benefit of today's control systems. And don't forget the Chineese who were the first (I think) to make practical skyrocket fireworks. It makes on think again about the role of the stick in a bottle rocket.
Although it is attractive to view a rocket standing on fixed rear-mounted engines as an inverted pendulum and a rocket hanging from fixed front-mounted engines as a normal pendulum, both views are incorrect. Let us neglect the influence of air resistance for the moment...
In an inverted pendulum, the unbalancing torque increases as the tilt angle increases. In a rocket with rear-mounted motors, the unbalancing torque does not increase. As the rocket tilts, the motors tilt along with it. Their relative angle remains fixed and the unbalanced torque remains unchanged. The result is a fixed angular acceleration for the rocket.
In a normal pendulum, the restoring torque increases as the tilt angle increases. In a rocket with front-mounted motors, the restoring torque does not increase. As the rocket tilts, the motors tilt along with it. Their relative angle remains fixed and the unbalanced torque remains unchanged. The result is a fixed angular acceleration for the rocket.
