Rod falling faster than gravity
The discussion centers on a Harvard article about a rod that falls faster than gravity when pivoted. Key points include the derivation of the formula, specifically the use of cosine instead of sine, which relates to the perpendicular distance from the pivot to the line of force. The acceleration at the rod's end is calculated using the full length L rather than L/2, as R is defined as half the rod's length. The conversation also touches on the implications of adding mass and tension to the system, questioning how torque would be affected. Overall, the mechanics of the rod's motion and the forces involved are critically examined.
Michal Fishkin
Harvard University has an interesting article on a rod whose end that falls faster than gravity around a pivot.
http://sciencedemonstrations.fas.harvard.edu/presentations/falling-faster-g
How did they derive this formula?
Where R is length of rod/2, or the centre of mass.
Why did they use cos instead of sin?
Also, in this formula
Why did they use Lcos instead of L/2 cos?
The article is interesting indeed but the effect is well known for ages. Take a ##\Gamma-##shaped tube in the vertical plane such that the shoulders of this tube are vertical and horizontal. Put a chain in this tube such that half of this chain is contained in the vertical shoulder. Due to gravity the chain begins to slide and the acceleration of its links is very greater than g till a part of the chain remains in the horizontal shoulder
Thank you but I am still unsure about the derivation.
The weight of the rod has a component directed through the pivot and a tangential component causing acceleration.
Likes Michal Fishkin
Note that θ is the angle that the board makes with the horizontal, not the angle between the R vector and the weight. (If that was what you were thinking.)
You can also think of Rcosθ as the perpendicular distance between the line of the force (gravity) and the pivot. Or you can think of Mgcosθ as the component of the weight perpendicular to the board. (That was John Park's point.)
They want the acceleration at the end of the rod, which has length L. (Note that R = L/2.)
Thanks everyone! :)
If the end of the rod was also be attached and pulling down on some mass M, would the torque also consider tension in the force?
  • · Replies 31 ·
