Rolling Sphere Oscillating on Spring
The discussion centers on calculating the period of motion for two uniform solid spheres connected by a rod and influenced by a spring, assuming simple harmonic motion. Initial calculations led to confusion regarding the total mass and moment of inertia, particularly concerning the rolling without slipping condition. After several revisions, the correct moment of inertia was established, leading to the formula T = 2π√(7M/5k) for the period. The final calculated period was found to be approximately 0.762 seconds after resolving the issues with the mass and inertia. The participant confirmed their final answer as correct, addressing concerns about modeling the two spheres accurately.
timmastny
Two uniform solid spheres, each with mass 0.862 and radius 8.00×10−2 , are connected by a short, light rod that is along a diameter of each sphere and are at rest on a horizontal tabletop. A spring with force constant 164 has one end attached to the wall and the other end attached to a frictionless ring that passes over the rod at the center of mass of the spheres, which is midway between the centers of the two spheres. The spheres are each pulled the same distance from the wall, stretching the spring, and released. There is sufficient friction between the tabletop and the spheres for the spheres to roll without slipping as they move back and forth on the end of the spring.
Assume that the motion of the center of mass of the spheres is simple harmonic. Calculate its period.
\tau=I\alpha
F = ma
F_{x}=-kx
M = mass total
\omega=sqrt(k/m)
EF = F_{static}-F_{x} = Ma
F_{static}-kx = Ma
I = 2/5MR^{2} + MR ^{2}
I = 7/5MR^{2} (Moment of inertia around contact with Ground because it rolls without sliding.
\tau_{tot}=-F_{static}R = 7/5MR^{2}(a/R)
-F_{static}= 7/5 Ma
With -F_{static} in hand, I placed it back into the translation force equation
-7/5Ma -kx = Ma
and
-kx = 12/5 Ma
Solving for a
a = -(5k/12M)x
now a = \omega^{2}x so
\omega = sqrt(5k/12M)
Finding period T
T = 2pi/\omega
or 2pi * sqrt(12M/5k)
Putting in m and k I found .706 s
Since the problem says their are two spheres touching the ground, would I have to alter my answer? I don't know how rolling without sliding works with two bodies on an axle. Would the moment of inertia be doubled? Thanks for the help
This is my first time, sorry if my formatting is off. I attempted to make it as clear as possible.
UPDATE: I couldn't figure out what was wrong with my previous answer, but I found something I did wrong in my calculators. I was using big M to denote total mass.
However in my calculations I was multiplying by .862
Revised with total mass 1.724 and plugging into 2*pi*sqrt(12M/5K) I found
T = .998
EDIT: Still incorrect
UPDATE: Rereading the section on Rolling without Slipping, I'm not sure I'm supposed to set
F_{static}R = I\alpha
where I follows the parallel axis theorem.
So instead of I = 2/5MR^{2}+MR^{2} I think it should just be equal to I = 2/5MR^{2}
That said, I have tried this solution but I was still caring the mistake I found in my last updated. With Updated values for I, I find
\omega=sqrt(5k/7M)
and
T = 2*pi*sqrt(7M/5K)
Pulling in TOTAL mass of spheres and constant K, I find
T = .762
--- does anyone think this looks correct? I'm still very unsure because there are technically two spheres rolling on the ground, and I am at a complete loss at how to model that.
EDIT: I was right.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 35 ·
  • · Replies 97 ·
  • · Replies 42 ·
10K
