Is x equal to the 4th root of y in the equation y=x^4?
  • Thread starter Thread starter Jhenrique
    Root
In the equation y=x^4, x is equal to ±√[4]{y}, as this represents the real solutions when y is non-negative. The discussion clarifies that while there are two real fourth roots for positive y, if y is not positive, all roots are complex. The notation used for absolute values and norms is debated, with suggestions that simpler expressions would suffice. The inverse function of f(x) = x^4 is correctly identified as f^{-1}(x) = √[4]{x} when the domain is restricted to non-negative x. Overall, the conversation emphasizes the importance of clarity and simplicity in mathematical expressions.
Jhenrique
If ##y=x^4##, so x is equal to ##\pm \sqrt[4]{y}## or x is equal to ##\pm \sqrt[2]{\pm \sqrt[2]{y}}## ?
Well, I think that x is qual to ##\pm \sqrt[4]{y}## because
\\y=x^4
\\\sqrt[4]{y} = \sqrt[4]{x^4} = \sqrt[2]{\sqrt[2]{(x^2)^2}} = \sqrt[2]{|x^2|} = \sqrt[2]{|x|^2} = ||x|| = |x|
\\ \pm \sqrt[4]{y}=x
Right!?
Mathematics news on Phys.org
If y is non-negative, this is indeed the real solutions for x.
\\y=x^4
Right!?
This is a basic algebra question that you should be able to answer for yourself.
If y = 16 = 24, then y = ##\pm##2. These are the only real fourth roots of 16. The other two roots are imaginary.
Some of what you wrote above is unnecessary, such as replacing x2 by |x2|. If x is real, then x2 ≥ 0, so x2 and |x2| represent the same number.
This notation -- ||x|| -- means the norm of x, in which the context is usually that x is a vector or something in a vector space. It's overkill to use ||x|| when all you mean is the absolute value, |x|.
Note that people are saying "the real roots". If y is a positive real number then it has 2 real fourth roots and two imaginary roots. If y is not a positive real number then all four fourth roots are complex numbers.
A) ||x|| isn't the norm of, is the abs of abs of x.
B) I didn't omit the abs in |x|² for efect of step-by-step.
C) All roots of equation ##y = x^4## is given by ##x=\pm\sqrt[2]{\pm\sqrt[2]{y}}##. But, if ##f(x) = x^4##, the inverse function is given simply ##f^{-1}(x) = \pm \sqrt[4]{x}##. Also, if ##f(z) = z^4##, thus maybe the inverse function is probably given by ##f^{-1}(z) = \pm\sqrt[2]{\pm\sqrt[2]{z}}## and not by ##f^{-1}(z) = \pm \sqrt[4]{z}##. But, I don't know how to verify this, cause I don't know how and where I can plot a complex graphic.
Why do this? The absolute value of a real number is nonnegative, so there's no point in taking the absolute value again.
Then you're adding extra, unnecessary steps. All you need to say is that ##\sqrt{x^2} = |x|##. And as I mentioned in another thread, including the index of 2 on your square root is completely unnecessary. This is one of a number of shortcuts that we take in mathematics. For example, we rarely write 1x in place of x, or y1 when we mean y.
No.
What you wrote for the inverse is not a function. f is not a one-to-one function, so it doesn't have an inverse. However, if we restrict the domain to x ≥ 0, then f is now one-to-one, and its inverse is f-1(x) = ##\sqrt[4]{x}##. No ##\pm##.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
