Rotating blades and air’s resistance
The discussion revolves around the effects of air resistance on rotating blades, specifically focusing on how to calculate whether a rod can withstand the forces exerted by air drag during rotation. Participants explore the relevant physical principles, mathematical formulations, and material properties that should be considered in these calculations.
  • One participant inquires about how to calculate if a rod can withstand air resistance, asking which material properties, such as specific strength or tensile strength, should be considered.
  • Another participant provides the drag force equation and suggests using specific values for drag coefficient and air density, while also prompting for clarification on the equation's components.
  • Several participants discuss the integration of drag force over the length of the rod to determine total torque, with one participant detailing the steps involved in the integration process.
  • Questions arise regarding the meaning of variables in the equations, such as the definition of dr and how to apply it in calculations.
  • Participants express confusion about whether to use the full length of the rod or half when calculating torque for a single blade.
  • There is a discussion about unit consistency, particularly regarding the conversion of air density from g/cm³ to kg/m³.
  • One participant expresses a preference for a simplified formula derived from the integration process, while another participant presents a specific calculation scenario involving multiple blades and their parameters.
  • Finally, there is a request for guidance on how to relate the calculated torque to the material strength of the rod to determine if it will break or bend under the conditions described.
Participants generally agree on the need to calculate torque and consider material properties, but there is no consensus on the specific methods or interpretations of the equations involved. Multiple competing views on the application of the formulas and the definitions of variables remain evident throughout the discussion.
Limitations include potential misunderstandings of the integration process, variable definitions, and unit conversions. The discussion does not resolve these ambiguities.
This discussion may be useful for individuals interested in the mechanics of rotating systems, fluid dynamics, and material science, particularly in contexts involving engineering applications or theoretical physics.
Eagle9
Imagine that the electro motor is rotating the blades in air at sea level:
During this rotation the air impedes the blades’ rotation and if the blades rotate too quickly or if they are made of fragile material they will be simply broken. Can anybody tell me how can we calculate if the rod (with some certain mass, length, volume and rotational speed) withstands air’s resistance or not? Material’s which property should be taken into consideration when calculating this? Specific strength or tensile strength? :shy:
Read about drag force in
http://en.wikipedia.org/wiki/Drag_(physics )
The drag force is F = ½ρACdv2
Use Cd = o.82 for drag force on long cylinder, and ρ = 0.0012 g/cm3 for air. See long cylinder and other shapes in
http://en.wikipedia.org/wiki/Drag_coefficient
and to get total torque (force x distance from pivot), integrate from pivot point to end of rod.
Bob S
Bob S
Ok, let’s go step-by-step :smile:
First of all: did I write this equation correctly?
Also: What is A in numerator?
Which units should we use? Grams or kilograms? In SI system kilograms and meters are used, so perhaps we should use only them :smile:
What about V? Apparently this is value of linear velocity at rod’s end? :shy:
Lets start by assuming the angular rotation rate is ω radians per second. So the velocity at distance r from the center is v = ωr. Now suppose the blade is a rod of diameter x. So the frontal area of a length dr of the spinning rod is A=xdr. So the drag force on this section of the rod is
dF = ½ρCdAv2 = ½ρCd(xdr)(ωr)2
the torque dT caused by the drag on this section dr of the blade is
dT = ½ρCdr(xdr)(ωr)2
Now integrate from 0 to R (R is the length of the blade), and multiply by 2, because there are 2 sides, and you will have the total torque caused by the air drag. Use mks units, and the answer will be in Newton-meters (kg-m2/sec2).
[tex]T = \rho C_d\int_0^Rx \omega^2 r^3 dr[/tex]
Bob S
Bob S
I have got 2 questions:
1. What is this dr here?
Is this the length of the rod? But a bit later in your post this length is designated as R
2. So, this is final formula, right?
When I calculate that T what should I do after it? :smile:
Also: when you mentioned the length of the rod you probably meant the whole length of it, at both sides, but what if we had the rod at one side only?
if you want to calculate the torque for half of the rod use the formula bob s gave you and take half of the length, which is your variable r if i understand correctly.
so [itex]\frac{r}{2}[/itex] and when you insert it into the formula it should be [itex](\frac{r}{2})^3 = \frac{r^3}{8}[/itex]
dr is an infinitely small step along the length of the blade between the axle (r=0) and the tip (r=R).
R is the length of each blade. If there are two blades, then the rod length is 2R.
After integration, substitute into the result the values for each variable. Use mks values.
The equation for the torque T is for two blades, each of length R. If you have only one blade, divide by two.
Bob S
Bob S
Ok, but what number should I write there? :smile:
X is diameter of the rod as you said, but what about dr? :shy:
This confuses me a bit :smile: imagine that we have got such situation:
and the length of the blade is let’s say 1 000 meters, so what number should we write in that formulas? 1000 or 500? :rolleyes:
Eagle9 said:
Bob S
dr is the variable of integration. It is infinitely small, and disappears when you do the integration (before putting in numbers).
R in the equation for torque is the length of the blade, from the axis of rotation to the tip of the blade. Your illustration shows one blade of length R.
Bob S
Bob S
Use mks units
Use mks values
One note: these units imply “metre, kilogram, and/or second (MKS)” (http://en.wikipedia.org/wiki/MKS_system_of_units) but the density of air given by you is in different units:
ρ = 0.0012 g/cm3 so should I rewrite it as follows: 1.2 kg/m3 ? :rolleyes:
Eagle9-
For each blade of length R, the torque T is
[tex]T =\frac{ \rho C_d}{2}\int_0^Rx \omega^2 r^3 dr=\frac{\rho C_dx \omega^2 R^4}{8} Newton-meters[/tex]
Bob S
Bob S said:
Eagle9-
Bob S
Frankly saying I like this part very much, no integrals, just formula :smile:
[tex]T=\frac{\rho C_dx \omega^2 R^4}{8} Newton-meters[/tex]
So, let’s begin calculation. We have got the electro motor with rod at one side only (as depicted in my post 5). The length of the rod is 1 000 meters (R), air’s density (ρ) 1.2 kg/m3 (in meters and kilograms), Cd = 0.82, diameter (X) is equal to 2 meters. As for ω, let’s assume that is equal to 2.
And here we get:
Is this correct? :rolleyes:
Calculate the following:
4 blades
R= 0.5 meters
x=0.005 meters
ω = 2 pi x 30 radians per second (=1800 RPM)
Cd = 0.82
ρ = 1.2 Kg/m3
T = 5.4 N-m
Power (watts) = T·ω = 188 watts
Bob S
4 blades
R= 0.5 meters
x=0.005 meters
Cd = 0.82
ρ = 1.2 Kg/m3
T = 5.4 N-m
Bob S
Well, this is different matter-calculating the amount of energy needed for rotating the rod :smile: while being interesting still I am looking for other solution. We calculated the amount of Torque (T) and now we need to somehow connect this value to rod’s material’s strength in order to calculate/know if the rod is broken (or bent) during rotation due to atmospheric drag, how can we do that?
Material strength and bending moments are engineering problems. I can't help you. Can you use static mechanical engineering equations, because the loading forces are static?
Bob S
Where do you think should I re-open this thread in this forum to solve this problem? This thread is opened in Engineering > General Engineering branch and I thought it would be best place, so should I apply to Physics’ department? :smile:
Re-title this thread as "Maximum bending moment in rod" and re-post it in Mechanical Engineering forum. For completeness, you need to include mass per unit length.
I opened the new thread https://www.physicsforums.com/showthread.php?t=506562" and I hope I will receive complete answer, thank you for your contribution :smile:
9K
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 39 ·
17K
12K
