Calculating Acceleration and Forces in Rotating Rod with Fixed Hinge
The problem involves a thin rod of mass 0.630 kg and length 1.24 m, which is initially at rest and hanging vertically from a fixed hinge. An impulsive horizontal force is applied at the bottom end of the rod, and the task is to find the acceleration of its center of mass and the horizontal force exerted by the hinge.
  • Mixed
  • Participants discuss the calculation of torque and moment of inertia for the rod, as well as the relationship between net force and acceleration of the center of mass. Questions arise regarding the horizontal forces acting on the hinge and how to determine them based on the applied force and the system's equilibrium.
Participants have explored various approaches to understanding the forces acting on the rod and the hinge. Some guidance has been provided regarding the relationship between the net force and the hinge force, with ongoing clarification about the different perspectives of the rod as a rigid body versus a point particle.
There is a noted confusion regarding the transition between analyzing the rod as a rigid object and as a point-particle, which may affect the understanding of the forces involved.
yoran
A thin rod of mass 0.630kg and length 1.24m is at rest, hanging vertically from a strong fixed hinge at its top end. Suddenly a horizontal impulsive force (14.7î)N is applied to it. Suppose the force acts at the bottom end of the rod. Find the acceleration of its center of mass and the horizontal force the hinge exerts.
Rotation of a rigid object.
I found the acceleration of its center of mass without problems. First I computed the torque done by the external force.
\sum{\tau}=FL
with L the length of the rod and F the magnitude of the external force.
Because it's a rod that is rotated about one end, the moment of inertia is given by
I=\frac{1}{3}ML^2
with M the mass of the rod.
We can use that the net torque applied to a rigid object is proportional to the angular acceleration.
\sum{\tau}=I\alpha \\<br /> \Leftrightarrow FL=\frac{1}{3}ML^2\alpha \\<br /> \Leftrightarrow \alpha = \frac{3F}{ML}
Furthemore, the acceleration of the center of mass is given by
a_{CM}=\frac{L}{2}\alpha=\frac{3F}{2M}
I have problems with finding the horizontal forces that act on the hinge. I know that in the vertical direction it has a force exerted on it directed upwards and equal in magnitude to the gravitational force exerted by the rod. Otherwise, it wouldn't be in equilibrium. Is that correct? Now, how do I find the horizontal force it exerts?
Hint: You found the acceleration of the center of mass. What does that tell you about the net horizontal force on the rod?
Well, because
\sum{F}=Ma_{cm}
then the force on the rod is
Ma_{cm}=\frac{3}{2}F
Is that also the horizontal force on the hinge then?
No, that's the net force at that instant. You know the applied force, so figure out what the hinge force must be.
Hmmm, I think I get it. The net force on the center of mass is
\sum{F}=F+H
with H the hinge force.
Also according to Newton's second law,
\sum{F}=Ma_{cm}
so
F+H=Ma_{cm} \\<br /> \Leftrightarrow H=Ma_{cm}-F \\<br /> \Leftrightarrow H=\frac{1}{2}F
Is that the correct answer?
Looks good to me!
Ok thank you for your time. I find it a bit confusing that sometimes you look at the rod as a rigid object rotating about the hinge, and sometimes you look at it as a point-particle.
  • · Replies 95 ·
