Calculating Maximum Revs/Sec w/ Speed c & Circumference of Disk
  • Thread starter Thread starter QuantumHop
    Rotation Speed
The maximum revolutions per second (mrps) for a disk is calculated as the speed of light (c) divided by the circumference (C) of the disk, expressed as mrps = c / C. While this formula appears straightforward, relativistic effects such as length contraction complicate the scenario, particularly regarding the disk's circumference in different frames. The velocity in the lab frame remains consistent at 2πr revolutions per second, but the disk's own frame presents a larger circumference. The Ehrenfest paradox is referenced to illustrate these complexities. Understanding these relationships is essential for accurately determining maximum rotational speeds in relativistic contexts.
QuantumHop
I'm assuming the maximum number of revolutions per second for a disk is defined as speed c divided by the circumference of the disk, eg a disk with a circumference of half a meter is allowed to rotate twice as fast per second as a disk with a circumference of one meter.
C = circumfrence of the disk
c = speed of light
mrps = maximum revolutions per second (not meters per second)
So is the value of mrps nice and simple : mrps = c / C
Or are there more complicated relativistic affects, for example does the circumference shrink due to length contraction.
The relationship that the velocity in the lab frame is 2*pi*r* revolutions / second, where r is the radius in the lab frame, doesn't change in the lab frame. The circumference of the disk in its own "frame" (which is not really a frame!) is different (larger) than 2*pi*r however. See any of the threads about the Ehrenfest paradox.
I thought something strange was going to happen but wasn't sure, thanks for the info.
I found this link, http://en.wikipedia.org/wiki/Ehrenfest_paradox
But I can't follow most of the math, why are they complicating things by using radius * pi? If I know the circumference I don't need pi. A circumference of 1m means it can rotate 299792458 times a second.
Oh wait I think I see why they don't use its circumference.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 20 ·
9K
