Undergrad Rotating Molecules: Energies, Angular Momentum & Wavefunctions
  • Thread starter Thread starter kelly0303
    Molecules Rotation
The discussion focuses on the rotational motion of molecules, specifically addressing the rigid rotor model where energies are expressed as ##BJ(J+1)## and wavefunctions as spherical harmonics. It clarifies that while the wavefunction remains consistent across frames, its mathematical representation varies depending on the chosen frame of reference. The angular momentum is defined differently in the center of mass (CM) frame and the laboratory frame, with three rotational quantum numbers: total angular momentum ##J##, projection in the lab frame ##M_J##, and projection in the molecule frame ##K##. The confusion regarding frame dependency of energy and angular momentum is resolved by emphasizing the distinction between translational and rotational motion.
  • Understanding of rigid rotor model in quantum mechanics
  • Familiarity with spherical harmonics and their applications
  • Knowledge of angular momentum in quantum systems
  • Basic concepts of frame of reference in physics
  • Study the rigid rotor model in quantum mechanics
  • Explore the mathematical representation of spherical harmonics
  • Learn about angular momentum quantization in quantum systems
  • Investigate the implications of different frames of reference on physical measurements
Students and researchers in quantum mechanics, particularly those focusing on molecular rotation, angular momentum, and wavefunction analysis.
kelly0303
Hello! I am a bit confused about the rotational motion in molecules. Assuming the bond length is constant, the motion can be described as a rigid rotor. In the center of mass frame the energies are given by ##BJ(J+1)## and the wavefunctions are spherical harmonics. However when we measure the energies or the angular momenta, we do it in lab frame. So I am a bit confused. Is the formula for the energy the same both in lab and CM frame? And if not, what is the formula in the lab frame? Also, is the wavefunction the same in both frames or, in other words, is the angular moment of the molecule the same in both frames. Actually I am a bit confused about how is the angular momentum defined in the CM frame. Isn't the molecule stationary in that frame? Yet the wavefunctions in the CM frame (spherical harmonics) do show a clear angular momentum dependence. Can someone help me clarify these things? Thank you!
Should the energy be frame dependent?
The wave function is the wave function and is independent of any representation. However, its mathematical expression will differ dependent on the choice of representation (just like for the comparison between its representation in momentum space compare to position space).
No, because what you separate is the translation of the center of mass. You then get a Hamiltonian corresponding to the relative displacement of the atoms (vibrations) and the overall orientation of the molecular frame (rotations).
Note that there are three rotational quantum numbers: the total angular momentum ##J##, the projection of the total angular momentum on the z axis is the lab frame, ##M_J##, and the projection of the total angular momentum on the z axis is the molecule frame, ##K##. (The latter is not used for linear molecules, such as diatomic molecules, where only ##K=0## is possible.)
  • · Replies 0 ·
