How Does a Spinning Bicycle Wheel Defy Gravity?
A spinning bicycle wheel maintains its vertical position due to the principles of angular momentum and gyroscopic stability. When the wheel is spun, the forces acting on it create a torque that results in precession, allowing it to resist changes in orientation. Once the wheel stops spinning, it loses this stability and falls to a horizontal position. This phenomenon illustrates the fundamental concepts of rotational motion and gyroscopic effects. Understanding these principles can enhance comprehension of various physical systems and their behaviors.
AARMA
In a class demonstration, a bicycle wheel was held on an axle and spun. The result came to be that the wheel while rotating held a vertical position while holding it by a string attached to the end of the axle. After the wheel stopped rotating its vertical position ceased and the wheel attained a horizontal position.
How and why does that happen?
can someone explain with his own words.. :)
On physicsforums:
See this post from november 2010 about https://www.physicsforums.com/showpost.php?p=2992527&postcount=3".
More detailed discussion is in the http://www.cleonis.nl/physics/phys256/gyroscope_physics.php" article on my website.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 22 ·
