Rotational Kinematics of bicycle breaks
The discussion revolves around the rotational kinematics of bicycle brakes and a spinning roulette wheel. The original poster presents two distinct problems involving angular velocity, angular displacement, and angular acceleration, seeking assistance in solving them.
  • Mixed
  • Participants explore the equations of motion for rotational dynamics, questioning the appropriateness of the equations used for non-uniform motion.
  • Some participants suggest re-evaluating the assumptions made regarding angular displacement and the conversion between revolutions and radians.
  • There is an exploration of how to derive angular acceleration and time from the given parameters.
  • Participants also discuss the initial conditions for the second problem, particularly the initial angular velocity of the roulette wheel.
Guidance has been offered regarding the correct equations to use for uniformly accelerated motion, and some participants have provided calculations based on their interpretations. There is a recognition of the need to convert units and clarify initial conditions, indicating a productive direction in the discussion.
Participants note the importance of understanding the distinction between revolutions and radians, as well as the implications of uniform acceleration in the context of the problems presented. There is also mention of confusion regarding the second problem, highlighting the complexity of the concepts involved.
tem_osu
[SOLVED] Rotational Kinematics
A person is riding a bicycle, and its wheels have an angular velocity of +18.0 rad/s. Then, the brakes are applied and the bike is brought to a uniform stop. During braking, the angular displacement of each wheel is +13.5 revolutions.
(a) How much time does it take for the bike to come to rest?
(b) What is the angular acceleration of each wheel?
(a) θ = (ω0 + ω)t
(b) ω = ω0 + αt
(a) +13.5 rev = (18.0 rad/s - 0 rad/s)t
t = (+13.5 rev)/(18.0 rad/s) = 0.75 - wrong answer
(b) (ω - ω0)/t = α
(0 rad/s - 18.0 rad/s)/0.75 = α - wrong answer
After 10.0 s, a spinning roulette wheel at a casino has slowed down to an angular velocity of +1.70 rad/s. During this time, the wheel has an angular acceleration of -5.05 rad/s^2. Determine the angular displacement of the wheel.
ω^2 = ω0^2 + 2α(θ − θ0)
(+1.70 rad/s)^2 = 0 + 2(-5.05 rad/s^2)θ
θ = [(1.70 rad/s)^2]/2(-5.05 rad/s^2) = -0.286 - wrong answer
Please help me, I don't know what I'm doing wrong.
Start with 1). Your equation a) is wrong. This is accelerated motion. The equation should be:
theta=omega_0*t+(1/2)*alpha*t^2. Solve your equation b) for alpha and substitute that into a). Now the only variable is t.
(a) θ = (ω0 + ω)t
(b) ω = ω0 + αt
The equation you have listed as (a) is only valid for uniform angular velocity. Since the wheel is slowing down, velocity is not constant, so you have to use an equation for uniform acceleration (since the problem states that the wheel comes to a uniform stop).Since the acceleration is uniform, you can assume that [itex]\alpha = \frac{\Delta\omega}{\Delta t}[/itex].
equation 1: θ = ω0t + 1/2αt^2
equation 2: ω = ω0 + αt
(ω - ω0)/t = α
solve for α from equation 2 & plug into equation 1:
θ = ω0t + 1/2[(ω - ω0)/t]t^2
θ = ω0t + 1/2[(ω - ω0)]t
13.5 = 18.0t + 1/2(0 - 18.0)t
13.5 = 18.0t - 9t
13.5 = 9.0t
t = 1.5 seconds - but it's still wrong
Did I simplified it wrong?
A 'rev' is not a 'rad'. How many radians is 13.5 revolutions? Other than that, well done.
(a) 13.5 x 2Pi = 9.0t
t = 9.42 s
(b) (0-18.0 rad/s)/9.42s = -1.91 rad/s^2
Thank you so much.
I'm still confuse about the second problem though. I tried several ways, but I've gotten some weird answers.
omega_0 in that problem isn't zero. The wheel starts at velocity omega_0, slows down at a rate of -5.05rad/sec^2 for 10 sec. Then it's speed is 1.7rad/sec. Can you figure out the correct value for omega_0. Think about it...
ω = ω0 + αt
ω - αt = ω0
(1.70 rad/s) - (-5.05 rad/s^2)(10.0 s) = ω0
ω0 = 52.5 rad/s
ω^2 = ω0^2 + 2αθ
(1.70^2) = (52.2^2) + 2(-5.05)θ
θ = [(1.70^2) - (52.2^2)]/(2 x -5.05) = 269.5 rad
GOT IT!
Thank you so much for helping me. ^-^
  • · Replies 19 ·
