Rotational Kinematics-YoYo Dropping from Ceiling
  • Thread starter Thread starter Darkalyan
    Rotational
The discussion focuses on the analysis of a yo-yo's motion as it drops from a ceiling, specifically addressing the conversion of potential energy (PE) to kinetic energy (KE) in both translational and rotational forms. The correct final kinetic energy equation is established as KE = ½Mv² + ½Iω², where the moment of inertia I for a solid cylinder is I = (MR²)/2. The relationship between linear velocity (v) and angular velocity (ω) is clarified as v = ωR, leading to the derived velocity of the center of mass as v = sqrt(-4gh/3). The participants confirm the accuracy of the calculations and the simplification of the kinetic energy in terms of R, M, and v.
  • Understanding of rotational dynamics and energy conservation principles.
  • Familiarity with the equations of motion, specifically v² = vi² + 2aX.
  • Knowledge of moment of inertia, particularly for a solid cylinder: I = (MR²)/2.
  • Basic grasp of angular velocity and its relationship to linear velocity in rolling motion.
  • Study the principles of energy conservation in rotational systems.
  • Learn about the dynamics of rolling motion and the concept of rolling without slipping.
  • Explore the derivation of kinetic energy equations for various shapes and forms.
  • Investigate the applications of rotational kinematics in real-world scenarios, such as in machinery and sports.
Students of physics, particularly those studying mechanics, educators teaching rotational dynamics, and anyone interested in the practical applications of energy conservation in rotational systems.
Darkalyan
Here's the problem in a JPG, with the image:
http://docs.google.com/Doc?id=d277r7r_50c9trfbdr
(the 25 points is b/c it's a practice test)
A)KE=0, PE=0 (defined to be at cylinder's initial position)B)PE=Mg(-h)C)Final KE=.5*M*(2gh)^2 (To get this, I used the v^2=vi^2 + 2aX equation, plugged it in for v^2 in KE=.5mv^2)However, I don't think my equations are right because if my KE was that, there would have to be extra energy put into the system for the yo-yo to rotate at all, thus there would be no rotational kinetic energy, which doesn't seem to jive with the original provlem. Where am I going wrong?
You are quite correct about you last eqn.
The final KE = ½Mv² + ½Iω²., where ω is related to v. This should take take of your problem.
Okay, so I know that I=(MR^2)/2, but you said that w is related to v. I don't see the relation?
Without giving you a direct answer, think of the angular displacement of any point on the disk and its relationship to the distance traveled by the centre. What is the relationship between the v and ω of a wheel rolling without sliding? I am sure you can take it from here.
Hmm. Okay. So, if there's rolling w/out slipping, then v=wR. I then plugged that into the fact that -Mgh=½Mv² + ½Iω², and plugged into the w (that w=v/R). I did a bunch of algebra, and got that v=sqrt(-4gh/3), which works out to be a positive # b/c h is defined to be a negative distance fallen. Is that the right answer for the velocity of the center of mass?
Looks good, but I fail to see where the "lot" of algebra came in.
[-Mgh = ½Mv² + ½Iω² = (3/4)Mv², by putting ω=v/R , cannot be counted as a lot of algebra...:cool:]
However, looking at the original question, you are supposed to give the KE-rot in terms of R, M and v. That would just be (1/4)Mv².
I think that covers everything. Good job.
Sorry, I'm kind of lazy when it comes to simplification, so that's why I thought it was a 'lot' of algebra :). Thank you very, very much for your help.
  • · Replies 21 ·
