Satellite mechanics: linear and rotational momentum
35 replies · 4K views
haruspex said:
If you choose an axis on the line of motion of the mass centre then it does not contribute any angular momentum
it does. A rotary one. Moment of inertia*angular velocity
on Phys.org
*shudder*. I think I see it. 100 kg m/s of linear momentum and 50 kg m2/s of angular momentum from rotation. He is taking the ratio of two quantities which have different units and pretending that the result is a dimensionless two to one ratio.
Naturally, the linear momentum is also 10,000 kg cm/s of linear momentum and 500,000 kg cm2/s of angular momentum from rotation for an equally defensible one to fifty ratio. "Equally defensible" because neither is at all defensible as a dimensionless ratio.
Two per meter and one per fifty centimeters are both the same ratio. Both have units.
Reply
One half per meter and one per fifty centimeters are both the same ratio. Both have units.
Yes, that's probably the blunder. I was thrown by
vasya said:
angular momentum in linear … motion
taking that mean the linear momentum's contribution to angular momentum.
jbriggs444 said:
An expanding plume of rocket exhaust of unknown mass and velocity that has 100 kg m/s of linear momentum at an offset of 0.5 meters from the craft's center of mass for a total of -50 kg m2/s.
look more closely on first picture in this thread. thruster has offset of 0.25m of y-piersing-through-the-center-of-mass axis
Reply
Thank you. That explains the factor of two discrepancy in our two evaluations for rotation rate.
