Scalar Potentials and Electromagnetic Current
The discussion focuses on deriving the scalar potential, charge density, and electromagnetic current for a copper solenoid and dipole using Lorenz invariant equations. The equations presented include the relationship between scalar potential and charge density, as well as the magnetic field calculations using the magnetic potential of a dipole and the Biot-Savart law. The complexity of the Earth's magnetic field is highlighted, noting that it does not conform to a simple dipole model and suggesting the Gaussian model for better approximations. Additionally, there is interest in calculating the magnetic moments of other planets and the sun, while acknowledging the challenges involved. The conversation emphasizes the need for more accurate mathematical models to represent these magnetic fields.
Philosophaie
For a Dipole and a Torad (or a Solenoid) I need to find the scalar Potential,phi, Charge Density,rho, and then 4-Electromagnetic Current,J(rho*c,j) where A and J are 4-vectors and a and j are 3-vectors.
-grad^2(phi) + 1/c^2*d/dt(phi) = rho/epsillon0
where grad(A(phi/c,a)) = -1/c^2*d/dt(phi)
-grad^2(A(phi/c,a)) + 1/c^2*d/dt(A(phi/c,a)) = mic0*J(rho*c,j)
I need a little help deriving rho, phi and J for a copper solenoid of diameter, d.
This is not a homework problem this is for my personal use.
Is there any reason you want to solve everything in terms of Lorenz invariant equations? The 3-magnetic field of a dipole can be found by looking at the magnetic potenial ##\mathbf{A}## of a dipole and the field from a solenoid can be found using the Biot-Savart law.
The magnetic fields of the Earth (Neglecting the Sun Fields, Solar Wind, etc.) can be calculated by using the magnetic moment. The magnetic moment is located on the z-axis relative to the x- plane of the equator. What is the magnitude of this magnetic moment so the others can be calculated? Also could this be calcated for the other planets and the sun (neglecting its periodic nature).
Not quite. The magnetic field around the Earth and other planets is rather complicated and does not match that of a simple dipole even when ignoring external influences. Here are some magnetic maps showing different elements of the Earth's magnetic field.
https://www.ngdc.noaa.gov/geomag/WMM/image.shtml
The Gaussian model of Earth give a better approximation but is very difficult to formulate. Are there other mathematical models to give better approxs?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
