Scattering amplitude of diffracted beam by a crystal
1 reply · 3K views
Andreasdreas
The scattering amplidtude, F, of a, by a crystal, diffracted beam is defined to be:
(1) [itex]F=\sum{_\vec{G}}\int n_{\vec{G}}e^{i(\vec{G}-\delta\vec{k})\cdot \vec{r}}\mathrm{d}V[/itex]
The integral is over all the volumeelements, dV, of the crystal.
[itex]n_{\vec{G}}[/itex] is the local electron concentration of the crystal in dV, [itex]\vec{G}[/itex] is a reciprocal lattice vector and the sum is over the set of all the reciprocal lattice vectors. [itex]\vec{r}[/itex] is the position vector of dV
further [itex]-\delta\vec{k}=\vec{k}-\vec{k'}[/itex] where [itex]\vec{k}[/itex] is the wave vector of the incomming beam and [itex]\vec{k'}[/itex] is the wave vector of the outgoing scattered beam.
The beam could be
fotons, electrons neutrons etc. It is descibed as a plane wave.
It is easy to see that [itex]F=n_{\vec{G}}V[/itex] when [itex]\delta \vec{k}=\vec{G}[/itex]
But how can it be shown that F is negligibly small when [itex]\delta \vec{k}[/itex] differs sginificantly from any [itex]\vec{G}[/itex]?
I thought some expression for the summation could be used.
Maybe
(2) [itex]\sum{_m=0}^{M-1}x^m=\frac{1-x^{M}}{1-x}[/itex]
I can't find a away to make (1) fit into (2). And if i just look at (1) i really am lost.
I thought of using the fact that the sum only goes over all the reciprocal lattice vectors and not \delta \vec{k}. This means that for \delta \vec{k} to be significantly different from any \vec{G}, then F should be small for the term in the summation that involves \delta \vec{k}.But how can one prove this mathematically?
