How Does Temperature Affect Pressure in a Sealed Fuel Tank?
The discussion revolves around the effects of temperature on pressure within a sealed fuel tank containing both liquid and gas phases. Participants explore thermodynamic principles, particularly focusing on how changes in external temperature influence internal pressure, the role of vapor pressure, and the behavior of liquid and gas phases under varying conditions.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions how pressure inside a sealed tank changes with external temperature, considering the initial composition of 3/4 liquid and 1/4 gas.
  • Another participant asserts that increasing the temperature in the tank (with fixed volume) will lead to an increase in pressure, which will equal the equilibrium vapor pressure of the substance, noting that this pressure increases with temperature.
  • A participant inquires whether it is possible to have only vapor in the tank if the temperature is raised sufficiently.
  • Another response clarifies that while it is possible for all liquid to evaporate at high temperatures, the pressure will still rise monotonically with temperature.
Participants generally agree that increasing temperature will lead to increased pressure in the tank, but there is a debate regarding the conditions under which only vapor can exist and the implications of liquid and vapor phases coexisting.
Participants discuss the effects of temperature on vapor pressure and the behavior of liquid fuel, but there are unresolved assumptions regarding the specific conditions under which phase changes occur and the implications for pressure dynamics.
This discussion may be useful for individuals interested in thermodynamics, particularly those studying phase behavior in sealed systems and the relationship between temperature and pressure in fluids.
hybro
Hi all,
I have some troubles with some basics thermodynamic rules. I have a sealed tank filled with fuel at Patm and at a temperature T. In this tank after filling, is composed of 3/4 liquid and 1/4 gas. I was wondering how the pressure inside the tank will change if we change the boundaries conditions (outside temperature). Will the pressure rise in the tank if the outside temperature goes up? Is it due to the vapor created because of the temperature variation (vapor pressure of the fuel?) or because of the liquid which exerce a pressure on the surface of the tank ?
With the perfect gas law we know that with the temperature the pressure will rise with the temperature but the vapor/liquid ratio will change too. And fuel is like incompressible so the tank expands too ?
Thank you for your help guys !
hybro said:
Hi all,
If you raise the temperature in the tank (with the tank volume held fixed), the pressure in the tank will increase. The pressure in the tank will be equal to the equilibrium vapor pressure of the substance, which increases with temperature (neglecting hydrostatic pressure variation in the liquid).
So that means we will always have liquid and vapor in the tank ? impossible to have only vapor if the temperature rise ?
No. Under certain starting conditions, of course, after you have raised the temperature enough, all the liquid will have evaporated. But, even here, the pressure rises monotonically with temperature.
  • · Replies 109 ·
9K
  • · Replies 28 ·
