How can I obtain a soft iron core for my electromagnet experiment?
Obtaining a soft iron core for electromagnet experiments can be challenging, as many local shops do not stock it. Alternatives include using scrap iron from hardware stores, such as mild steel bolts or nails, which can be annealed to achieve magnetic softness. Old transformers and induction motors are also good sources for soft iron, as they contain specially formulated steel with low hysteresis. For those unable to find soft iron, mild steel can serve as a substitute, but it may retain some magnetism after use. Overall, exploring hardware stores, scrapyards, and online suppliers can yield suitable materials for the experiment.
smokedvanilla
Hi, I am planning to conduct an experiment using electromagnet but I could not find the soft iron core.
My school lab doesn't have it, and I tried asking around in shops which sell electrical appliances and shops which sell science apparatus but nobody seems to sell it. Does anyone know where can I get one? And how many tesla should be sufficient for experiments involving magnetic levitation?
And also, I'd appreciate it if somebody knows anything that I could use to substitute soft iron core. Is it wise to use hard iron instead?
"soft" probably refers to its magnetic property, meaning it is not easy to permanently magnetize it.
You can experiment with scrap iron like a bolt or railroad spike, or take apart an old transformer.
Here's a link to a manufacturer of iron cores with educational material.
http://mag-inc.com/company/company-information-learn-more-about-magnetics
just one source , of many returned by a google search:
https://www.surplussales.com/Inductors/FerPotC/FerPotC-2.htmlone Tesla is a pretty strong magnet.
did you try a hardware shop, they would have all sorts of things made out of sort iron rod that you could put into use
or go to a building site and grab a 0.5 metre length of scrap reinforcing rod
Dave
Dave
A traditional method is to heat up a mild steel bolt or nail to cherry red using a Bunsen Burner and plunge it into water. It should look black.
Thank you for all of your replies.
I am planning to try using iron nail to see if it works, as the school can easily provide me with that. Unfortunately I don't have an old transformer.. :(
Thank you for the links, I will check them out! :)
Dave
Oh yea, I did not think of hardware shop! :D Is reinforcing rod soft iron tho?
I did not know you could make your own soft iron core that way. Thank you for the tips!
If you want the 'best' iron for experiments then you can do a lot worse than get an old transformer and saw it apart. You may need to struggle to get all the windings and the potting compound but the iron in the laminations is specially selected! Good luck and mind your fingers.
PS You could just use the transformer as it is - treat it like a lump of iron and forget about the windings - it's even good for AC as long as you don't connect the ends of the wires to each other.
If you try to do things with steel, you usually find that it has remnance and will not lose its magnetism once it's been touched with a strong magnet. This happens with nails, which are not chosen for their 'softness'.
Just beware of microwave oven transformers (aka MOT's). They have a high voltage winding that's dangerous. Saw the high voltage windings off a MOT first thing..
It's strange but there are fewer and fewer actual transformers in equipment these days. It's all switch mode PSUs and high frequencies. Shaded pole motors would be a good source of Iron but everyone uses brushless PM motors these days. But powerful magnets abound - hard drives and small motors are full of 'em.
easily bent by hand
davenn said:
easily bent by hand
Reinforcing rod?
It's made of steel, to be as strong as possible, surely. Likely to have high hysteresis. Soft Iron is pretty rare - except where it is used for its magnetic properties (e.g. in School Labs).
It used to be easy to buy kits for winding your own transformer. All I could find (a quick search) was this, which is a bit expensive but it has E and I laminations and you could make up your own core.
It is possible that Iron wire (v. soft) could be obtained from gardening stores. I did have a reel of it, a while ago.
The usual definition of soft iron - low carbon content iron. Annealing will make it easier to bend. Bendability - I do not think it has a lot to do with the softness of iron in this context.
I have two sets of nails for making electro magnets for school pupils, which I call steel and soft iron. The soft iron ones are annealed as I described, and they lose magnetism when the current is switched off. They are not actually soft physically. You will find the idea of annealing to make soft iron in old electricity books.
try a concrete "cut" nail. they're quite hard.
tech99, I would expect the sudden quench you describe to result in hardening if the material is at all harden-able. Instead, I would suggest after heating the material that you simply allow it to air cool, or even better to cool slowly in some sort of insulator (dirt?).
Soft iron, for the purposes at hand refers to being magnetically soft, not physically soft. Thus the hardness of the material, the sort of thing indicated by a Brinell hardness tester, is really immaterial for magnetic purposes. Further, relative few things are make from iron anymore; more often steel is used for strength.
THAT one hit the nail square on the head.
Thank you. We'll let you know
NEXT!. :wink:
'Soft' iron meaning 'magnetically soft' (low coercivity and retentivity) also happens to be physically soft. That is where the term 'soft' originates. This applies only to iron and steel; ferrites can be magnetically 'soft' or 'hard' but are always physically hard.
Sot iron ( also called magnet steel or 'commercially pure' iron) as used in magnetics is very low carbon-content steel, less than 0.05%. It can be ordered from industrial suppliers but may require minimum quantities and thus be expensive.
A good substitute is mild steel: with % C ranging from 0.06 (AISI 1006) to 0.3 (1030). Most-commonly encountered are 1010 (0.1% C) and 1020 (0.2%). Machine key stock, the zinc-plated stuff from your local hardware or home center, is generally of those grades. So are SAE Grade 2 bolts (also zinc-plated).
Structural steel (not concrete rebar, which being made from scrap can have wildly-varying carbon content) of mill (plain) finish, in plate or square bar form, typically used for decorative metalwork, can be obtained from the same sources or from junkyards. It is generally higher-carbon than mild steel, but can be made magnetically (as well as physically) soft by annealing. This is done by uniformly heating to cherry-red (about 1500 F), and allowing it to cool slowly. (Quick cooling--quenching--hardens steels of medium and high carbon content both physically and magnetically, which is good for permanent magnets, but the opposite of what you want.)
As others have mentioned, transformer and induction-motor cores are made of laminations of magnetically-soft steel of low carbon but high silicon content (the latter to increase resistivity thus reducing eddy-current losses) and are good when AC is involved (but work fine for DC too). These can be obtained cheaply from scrapyards as well.
For a supplier, try a blacksmith. Look under horse care if you have trouble finding one in your area.
I saw a levitating aluminum ring once which used straightened and bundled coat hangers. I can't swear to the metal type though.
I hadn't realized that soft iron EI core material was so difficult to come by. Hower McMaster-Carr does sell "gray iron" is all shapes. But what is gray iron?
Does anybody know of a material with high permeability in which the hysteresis curve is either big or small doesn't matter.
My physics teacher recommended soft iron binding wire (apparently now called black iron wire.) I haven't seen this around in hardware shops for a long time, but I suspect agricultural hardware shops and maybe even florists would still have it. It is available online at about 5 quid a kilo (>100m of 1.25mm diameter) or 2 quid 100g (plus carriage! So better to find somewhere local to collect.)
It was straightened by rolling the cut lengths between two sheets of plywood. Then given a coat of lacquer (whatever that is - paint?) for use with AC. I think the stuff we used was about 1mm diameter. I believe, for AC, thinner might be better, but more tedious, or for DC just use the thickest you can get.
You haven't said what shape core you want, or how big it should be. Do you want a "U" shaped core, or a simple straight piece of iron? Are you going to use with AC or DC?
You may be able to find a surplus core set such as these: http://www.magneticmetals.com/products/tape-wound-cut-cores
Where do you live? I may be able to direct you to a source if you're in the U.S.
I have used steel bolts and nails for school demonstrations. If you want the magnetism to go when you switch off the current, you can anneal the steel by heating to cherry red and plunging it into water. It is then black and magnetically soft, ie it loses its magnetism. Think in terms of a few hundred turns of wire.
Sophiecentaur that mentioned transformer steel is a good choice. It is specially formulated to have a small hysteresis loop for low magnetic losses, and as a side benefit it does not retain much residual magnetization. As was also mentioned, the rotors and stators of AC motors are made of similar steel. Transformer steel has a high silicon content. Old-fashioned wrought iron (hardware from a Victorian home, a piece of an iron fence from the 1800's, etc.) also has high silicon content, may be easier to find, and will serve in this role.
You can scrap out the mu-metal from an old hard drive.
Howie said:
If you're looking for soft iron rod, check out Surepure Chemetals. They have soft iron rod of various diameters and lengths:
http://www.surepure.com/Iron-Wire-Rod/a/17,1
A little bit pricey for a student, don't you think?
Do you mean the platter? Since it operates as a memory, it is a "hard" magnetic material by definition (and it isn't mu-metal). It also is a thin film, hence useless for building an electromagnet. You must be referring to something else.
10K
  • · Replies 43 ·
