Second order differential equations on forced vibrations
6 replies · 11K views · last reply
sskakam
A spring-mass system has a spring constant of 3 N/m. A mass of 2 kg is attached to the spring, and the motion takes place in a viscous fluid that offers a resistance numerically equal to the magnitude of the instantaneous velocity. If the system is driven by an externam force of 3 cos(3t) - 2 sin(3t) N, determine the steady-state response.
From the problem:
m = 2, k = 3, gamma = y' ?
2y" + y'[tex]^{2}[/tex] + 3y = 3 cos(3t) - 2 sin(3t), or in terms of delta and omega_0
y" + 2 (y'/4) y' + 3/2 y = 3/2 cos(3t) - sin(3t)
Don't know where to go from there. I need to find A, omega and gamma, but I don't know how.
Well for one thing, the y' in your differential equation should not be squared. The equation should be linear.
Does that help?
You may have interpreted this as saying that the coefficient is equal tot he magnitude of the instaneous velocity so the force is (-y')y'. But it says the force itself is: you want only -y'. Tom Mattson is correct.
try a solution of the form Acos(3t-delta) + Btcos(3t-delta). do you know why?
Not exactly. It looks very similar to the guess for undamped free vibrations, y = A cos(omega_0 t) + B sin(omega_0 t), and I can see where the -delta comes from (the damping part), but why 3t? Isn't 3 = omega, not omega_0? My omega_0 = [tex]\sqrt{3/2}[/tex], I think.
So my equation is 2y" + y' + 3y = etc.
Yes, that is correct.
I certainly don't see any reason to include the "delta" or "t". Acos(3t)+ Bsin(3t) should be sufficient. Solutions to the homogeneous equation are nothing like cos(3t) or sin(3t).
Acos(3t-d) is compact notation for Acos(d)cos(3t)+Asin(d)sin(3t). and the reason for both is that i was under the impression that since the solution for an inhomogeneous part of something like y'=cos(t) is Acos(t-d) then the solution for y'=cos(t) + sin(t) is the sum of the solutions for cos(t) and sin(t) but those are the same hence the t multiplying out in front.
