Is there a strategy for combining the German tank and secretary problem?
  • Thread starter Thread starter Gerenuk
    German Tank
The discussion revolves around the challenge of combining the German tank problem with the secretary problem, focusing on maximizing the serial number of tanks observed. Participants note that the task involves estimating an unknown total number of tanks while only keeping the last observed tank. The distribution of serial numbers is considered, with uniform and normal distributions being discussed. A survey article referenced in the Wikipedia entry may provide insights into this combined problem. The conversation highlights the complexity of estimating values from different distributions while applying principles from both problems.
Gerenuk
Is it possible to give a strategy for the combined problem of
http://en.wikipedia.org/wiki/German_tank_problem
and
http://en.wikipedia.org/wiki/Secretary_problem
So I'm observing tanks with serial numbers and I'm allowed only the keep the last one. I also don't know how many there are in total. My task is to (increase change of getting the highest number) or (achieve the highest average serial number on the tank I'm keeping). The distribution of serial numbers is uniform. Another case would be if it's normal.
Basically it is the secretary problem with an unknown number of applicants, but moreover this unknown number if applicants has to be estimated given the observed incoming samples. The assumed distribution of all samples could be uniform or maybe also normal.
Has anyone heard of an article where this problem is considered? Or how do I find such an article?
Interesting problem. Have you tried the survey article that was listed in the wikipedia article references? It's from 1983 but might say if the same problem is solved under a different name.
Also, how could serial numbers be drawn from the normal distribution?
Actually I meant this as two different cases. Serial numbers from a uniform distribution. And on the other hand some other cardinal value from a normal distribution like the height of people (with apriori unknown mean height).
I just downloaded the survey article. Hope I find some time to go through it soon.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
