See Infrared in Naked Eye | Tips & Techniques
  • Context: High School
  • Thread starter Thread starter bomme08814
    Infrared
12 replies · 4K views
bomme08814
How to see infrared...?
Does anybody know how to see infrared in naked eye,except digital camera, which means with glass or other material...??
Your question is very vague- the IR spectrum is considerably broader than the visible, and is (for convenience) divided up into NIR (0.9-1.1 um), SWIR, MWIR (3-5 um), and LWIR (8-12 um). Some people go out even further. Detector materials for these different spectral regions vary: Si is ok for NIR, but MWIR and LWIR require InSb, PtSi, HgCdTe, or more exotic materials. Ge lenses are used in MWIR and LWIR applications.
Direct viewing of high levels of IR will (obviously) damage your retina since you don't have a blink reflex; so I am cautioning you to be careful.
I use a Nd:YAG laser in the lab, and some of my safety/alignment equipment is
http://www.kenteklaserstore.com/category.aspx?categoryID=11
And:
http://www.kenteklaserstore.com/category.aspx?categoryID=13
thank you so much for your answer...i appreciate that...now i can figure out what should i do...thanks
Short answer is 'no', it's beyond the visible spectrum so kind of by definition you can't see it with the naked eye.
Actually no...but if we use some application such as IR card... we can see that...the question is...i want to see by using some special material such as composite glass or polymer...
You can't, question answered.
IR sensors, can detect the IR wavelengths THEN convert it to a convenient visual format. So they can do a false colour image within the visible spectrum. Out skin can detect IR radiation as it can feel heat.
You simply can't use a piece of glass because you are still 'seeing' in the visible spectrum. Nothing like glass/plastic or any type of filter can 'shift' the IR wavelengths into visible light.
You can use dyes that react to heat to 'see' IR radiation, but not a precise visual image.
i understand now...thanks chris... :redface:,
what do you think if i use CCD camera...?
i try to use CCD camera, but the camera does not detect the IR... i think the camera was using infrared filter.
It's certainly possible to do with a CCD as they can detect IR, and some you can remove the ir filter.
I don't know anymore than that I'm afraid, someone round here will though.
Earlier models of video camera picked up in the IR range. There was a ferfuffle for a while since they could actually image right through people's clothes. Camera manufacturers took to installing IR filters in their camera to block this. But the filters can be removed.
You can run towards it very fast ...? and use less punctuation!
Not strictly true, there are non-linear materials that can combine two long wavelength (IR) photons into one short wavelength (Visible) photon - it's how most high power blue and blue-green lasers work
Here are cameras :
http://www.gentec-eo.com/en/products/beam-diagnostics.5.htm
