Segment of a circle calculation
In summary, the conversation discussed calculating the cross-sectional area of a lathe turned feature with a radiused insert using the equation for the area of a segment of a circle. The problem at hand was determining the central angle when a predetermined area was given. It was determined that finding a finite solution for x was not possible and only ordered pairs could be achieved through iterative approximation. Generalizations for a given "y" and an approximate "x" were also discussed, along with a suggestion for using a different formula to find the area of the segment. It was also mentioned that the answer for x will be in terms of "radians".
bergie7isu
I'm working to calculate the cross-sectional area of a lathe turned feature machined with a radiused insert. My calculations have essentially led me to the equation for the area of a segment of a circle.
Area=r^2/2*(∏/180*C-sin(C))
where r is the circle's radius and C is the central angle of the associated sector.
In this particular case, I have a predetermined area and need to determine the central angle. How do I solve for C?
In it's most basic form, I have:
y=x+sin(x)
Solve for x.
Any help is appreciated. Thanks!
Mathematics news on Phys.org
Basically, you can't find a finite expression for the inverse here.
However, various appoximative techniques might be used.
IF, for example, y is "sufficiently close to 0", a power series expansion about x=0 might zoom onto the solution fairly quickly.
To show how this might be done:
We have:
[tex]y=x+x-\frac{x^{3}}{3!}+\frac{x^{5}}{5!}+++[/tex]
when expanding the sine function in its power series (a finite segment of that highly accurate when x is close to zero)
We now invert the power series, by assuming:
[tex]x=a_{1}y+a_{2}y^{2}+a_{3}y^{3}+++[/tex]
where the solution x(y) of the original equation boils down to determining the a's.
Inserting the latter in the former, we get:
[tex]y=2*(a_{1}y+a_{2}y^{2}+a_{3}y^{3}+a_{4}y^{4}+a_{5}y^{5}+++)-\frac{1}{6}(a_{1}^{3}y^{3}+3a_{1}^{2}a_{2}y^{4}+3a_{1}^{2}a_{3}y^{5}+3a_{2}^{2}a_{1}y^{5})+\frac{1}{30}a_{1}^{5}y^{5}++[/tex]
where terms of higher orders in y than 5 are dropped.
Now, we simply compare coefficients in each power to "y", to determine the a's.
We get:
[tex]a_{1}=\frac{1}{2}, a_{2}=0, a_{3}=-\frac{1}{48}, a_{4}=0, a_{5}=\frac{1}{640}[/tex]
Thus, to fifth order accuracy, you have:
[tex]x=\frac{1}{2}y-\frac{1}{48}y^{3}+\frac{1}{640}y^{5}[/tex]
Hmm, my coefficients were wrong.
We have:
[tex]a_{3}=\frac{1}{96}[/tex]
[tex]a_{5}=-\frac{1}{4800}[/tex]
or, I hope..:shy:
You'd better check for yourself.
arildno, I appreciate the response! Unfortunately, I can't assume y is close to zero in this situation. I agree with your guidance that a finite solution for x isn't possible. It seems that only ordered pairs are achievable (set a value for y, guess a value for x, and iterate until x converges on a solution). I generated a spreadsheet that does the iteration automatically. Thanks again for the help!
This situation is still a little tough to wrap my head around. It would seem that, with a finite area of a segment, I should be able to calculate the central angle. I've yet to intuitively explain why I can't calculate this feature when I have a real, finite, pre-defined segment area that I can measure.
#continuouseducation
It is determined, but calculability is another matter. We are accustomed to treating strandard functions as exact answers. E.g. if the answer to a problem is "x = sin(π/7)" you'd accept that. But in practice, since it is irrational, you can only turn that into a number by iterative approximation. If the problem's answer is "that x for which x+sin(x) = 2", we find that less satisfying, yet in reality it is no different. If answers of that form were to crop up reguarly in some contexts we might define a new function for it, and if we want a numerical answer we iterate.
It is not really that difficult to generalize to a given "y", and an "approximate" "x".
However, a general formula, converging fast to any "y"-value is not available.
(But, to any given "y", you ought to be able to find a fast converging series)
To generalize this, once you have a desired approximation X* for some "y" of yours (the closer X* is "y", the faster the convergence will be!), we may write:
[tex]x=X*+\epsilon[/tex]
where epsilon is some "small function" of "y" and X*
Inserting this into your equation yields:
[tex]y=X*+\epsilon+\sin(X*+\epsilon)=X*+\sin(X*)(1-\frac{\epsilon^{2}}{2}+-+)+\cos(X*)(\epsilon-\frac{\epsilon^{3}}{3!}+-+)[/tex]
Now, we arrange this to:
[tex]\frac{y-X*-\sin(X*)}{1+\cos(X*)}=\epsilon+\frac{\sin(X*)}{1+\cos(X*)}(-\frac{\epsilon^{2}}{2}+-+)+\frac{\cos(X*)}{1+\cos(X*)}(-\frac{\epsilon^{2}}{3!}+-+)[/tex]
Remember now that the numerator of LHS is "close to zero", by assumption that X* is an approximate solution!.
Breezing past, for now, the potential trouble of a "too small" denominator on LHS, we term LHS for "kappa", and expand "epsilon" in the power series.
[tex]\epsilon=a_{1}\kappa+a_{2}\kappa^{2}+++[/tex]
Thus, we get, trivially [itex]a_{1}=1[/itex], and to second order:
[tex]0=a_{2}\kappa^{2}-\frac{3\sin(X*)+\cos(X*)}{3!(1+\cos(X*))}\kappa^{2}[/tex]
that is:
[tex]a_{2}=\frac{3\sin(X*)+\cos(X*)}{3!(1+\cos(X*))}[/tex]
and so on.
Agreed so far?
Is this the part where I ask if anyone's thought of using a different formula? The basic formula for the area of a segment is [itex]A_{segment} = A_{sector} - A_{triangle}[/itex].
If we know the length of the chord between the outer endpoints of the radii and the distance from the center to that chord, the area of the segment can be found by [itex]A_{segment} = \frac{x r^2}{2} - \frac{hc}{2} = \frac{x r^2 - hc}{2}[/itex], where c is the length of the chord, h is the distance of the chord from the center, and x is in radians. In this case, [itex]x = \frac{2A_{segment}+hc}{r^2}[/itex].
If we can't find c and h, would it not be reasonable to say that [itex]\displaystyle y = x + sin(x) = x + \lim_{r→\infty}\sum_{n=0}^{r} \frac{(-1)^n x^{n+1}}{(2n+1)!}[/itex]? Thus, our approximation for x gets increasingly better as r approaches infinity.
Either way, remember that your answer for x will be in radians.
1. What is a segment of a circle?
A segment of a circle is a section of the circumference of a circle, bounded by a chord and an arc.
2. How do you calculate the area of a segment of a circle?
The formula for calculating the area of a segment of a circle is (1/2) * r^2 * (θ - sinθ), where r is the radius of the circle and θ is the central angle of the segment in radians.
3. What is the difference between a minor and major segment of a circle?
A minor segment of a circle is the smaller section of the circumference, bounded by a chord and an arc that is less than 180 degrees. A major segment is the larger section, bounded by a chord and an arc that is greater than 180 degrees.
4. How do you find the length of a segment of a circle?
The length of a segment of a circle can be calculated using the formula 2 * r * sin(θ/2), where r is the radius of the circle and θ is the central angle of the segment in radians.
5. Can a segment of a circle have a negative area?
No, a segment of a circle can never have a negative area as area is a measure of space and cannot be negative. However, if the central angle of the segment is greater than 180 degrees, the formula for calculating the area will result in a negative value. In this case, the absolute value of the result should be taken to get the actual area of the segment.
  • General Math
  • General Math
  • General Math
  • General Math
