Self charging keyboard - Is it possible or just funny?
In summary, it is possible to build a self-powered keyboard, but it is not practical and would require a lot of expensive hardware.
32
Last night I had a drink with my friend and short after he started talking about self charging keyboard. It is a wireless keyboard and it "could" be charged when you are typing ( mechanical to electrical ) or by cleaning it ( whipping off the keyboard with something and then electrons "would" be stored somewhere).
I think this is fairly funny but that can be good brain teaser... So what do you guys think? I know that this was caused by "few" drinks but still... I would love it if someone could debunk this.
If by self charging you mean wireless charging, then yes it is a possibility. Much like the wireless charging pad Samsung has come up with.
Piezos are possibly the best option:
https://en.wikipedia.org/wiki/Energy_harvesting#Piezoelectric
Maybe under each foot, or under every key? my wireless KB states 50mA requirements (max), I'm not sure if that's a reasonable ask from piezos in this application. It may mean uncomfortably hard key action.
What energy conversion is happening here?
Maybe a way of taking in and using or storing natural body heat while the user uses the keyboard. Not sure how practical this is, but I'm sure there could be a way. Possibly using the keys or a wrist rest to take in the heat and convert it.
I think he's thinking of static cling via wiping.
Likes billy_joule
On that scale, Seebeck generators are probably most appropriate:
https://en.wikipedia.org/wiki/Thermoelectric_generator
So, yes, it is possible but probably not worth it. These sorts of micro power harvesting methods exist but I think you are applying a solution to a problem that doesn't exist - If you have a computer you clearly have access to power, even if only battery power from your laptop/tablet etc. Building a self powered KB is a waste of time and money (IMO) unless you go all out and power your entire device which would require something like this:
http://www.cnet.com/news/pedal-power-pedal-your-desk-to-power-your-laptop/
or a huge array of Seebeck generators and a roaring fire.
3301 said:
Last night I had a drink with my friend and short after he started talking about self charging keyboard. It is a wireless keyboard and it "could" be charged when you are typing ( mechanical to electrical )...
It is certainly possible in principle, so what is needed now is to figure out if it would be practical. See if you can find a wireless keyboard with listed battery specs from which you can calculate the power drain. Then try to calculate the power you could generate by typing based on the key stroke distance and force.
Likes CWatters
The AAA batteries in my keyboard lasts quite a few weeks
I've got a calculator that runs off of light. There's a little strip that absorbs the stuff. It's about 40 years old.
Yeah but pocket calcs don't have to broadcast signals.
I tried to run some numbers but the tricky part for me was estimating how many key presses I average a day.
You could use a keylogger to keep track. Maybe track over the course of a week or two and then find the average.
I create around 4000 words per day and 5 letters aprox for one word.
My wireless KB has no power switch. This suggests it only transmits when used, or at least power drain when unused is negligible. So I don't thing key strokes/day is the important metric, the real question is if energy generation of a stroke > energy consumption of a stroke transmission.
@ billy_joule
energy generation of a stroke > energy consumption of a stroke transmission - Valid
The minimum we can get out from all of this is to extend battery life ... still need to calculate how much energy we can get from typing.
Unless you store the energy then average figures can be used to estimate feasibility.
Seems nobody else wants to do the sums so...
Lets assume that a pair of 1000mAH (1AH) AAA batteries power a keyboard for 4 weeks and the user types 4000 five letter words a day. So that many keystrokes would have to provide the same energy as the battery.
The number of keystrokes is 4 * 7 * 4000 * 5 = 560,000
The energy in the battery is 1.5 * 1* 3600 = 5400J
So each keystroke must provide 5400/560000 = 0.01J
Work = force * displacement
so
force = work/displacement
Lets say the useful key travel is 2mm or 0.002m..
Force = 0.01/0.002 = 5N
I think that's about an order of magnitude too high?
According to this..
https://www.kinesis-ergo.com/wp-content/uploads/2013/06/freestyle_vs_ms4000-800x3381.jpg
..typical keyboard forces are around 40-60 grams or 0.5N
Likes 3301 and gennarakis
Only 10%? That`s barely 3 more days of usage :)
I did, and got a similar answer (mine was all in terms of energy though), but wasn't going to share it with the OP...
CWatters said:
Think of it like regenerative braking: it would run for a month on the original charge, them 3 more days from what it harvested.
Likes CWatters
1. Is a self-charging keyboard actually possible?
Yes, a self-charging keyboard is possible and it already exists in the market. There are several companies that have developed keyboards with built-in solar panels or kinetic energy harvesting technology that allows them to charge themselves.
2. How does a self-charging keyboard work?
A self-charging keyboard works by using alternative energy sources such as solar power or kinetic energy to generate electricity. The keyboard is designed with small solar panels or sensors that can capture the energy from light or movement, which is then stored in a battery inside the keyboard.
3. How long does it take for a self-charging keyboard to fully charge?
The charging time for a self-charging keyboard varies depending on the type of energy source and the amount of energy needed. For example, a keyboard with solar panels may take several hours to fully charge on a sunny day, while a keyboard with kinetic energy harvesting technology may only take a few minutes of typing to generate enough energy for use.
4. Are there any disadvantages to using a self-charging keyboard?
One potential disadvantage of using a self-charging keyboard is that it may not work well in low light or low movement environments, which can limit its charging capabilities. Additionally, these keyboards may be more expensive than traditional keyboards, and they may not have the same tactile feel as regular keyboards.
5. Can I use a self-charging keyboard without any external power source?
Yes, a self-charging keyboard can be used without any external power source as long as it has enough stored energy to function. However, if the keyboard does not have enough energy and is unable to self-charge, it may need to be connected to a power source to work properly.
  • Quantum Physics
  • Electromagnetism
  • DIY Projects
  • Electrical Engineering
  • General Discussion
  • General Engineering
