Yes, the derivative of log(x) is 1/x.
  • Thread starter Thread starter TheBoro76
    Logarithmic Sem
To find the standard error for log(a) in the equation log(a) = log(b) + c, one can use the formula for the standard error of a sum, which involves the standard errors of b and c. The discussion emphasizes the importance of applying partial derivatives to combine errors in quadrature for functions of multiple variables. The analytical solution is preferred over a Monte-Carlo simulation, although the latter is also considered. The derivative of the log function, which is 1/x, is crucial for calculating the necessary partial derivatives. Understanding these concepts is essential for accurate error propagation in research contexts.
TheBoro76
Hi, this isn't exactly a homework question, but this seemed like the most appropriate place to put it.
I have an equation in the form:
log(a)=log(b)+c.
I also have standard errors (SEMs) for b and c. I want to find the standard error for log(a) (i.e. log(a) +/- E(log(a)))
I know the SEM of some quantity x, where x:=y+z, is given by Ex=sqrt(Ey^2+Ez^2)
The problem is really trying to find the error of the log.
In high school I would have solved it by choseing the largest of:
abs(log(b+Eb)-log(b)) and abs(log(b-Eb)-log(b)), where Eb is the SEM of b.
if we let this be g then
E(log(a))=sqrt(g^2+Ec^2)
However, given I am doing uni research I am not sure whether this would be acceptable.
I have also considered making a Monte-Carlo simulation of the problem. Drawing random numbers from the distributions b~N(b,Eb) and c~N(c,Ec) and finding the mean and standard deviation of the simulation. However I would like to get an analytical solution.Thanks in advance if anyone can help me out
When you have a function of several variables with errors a common approach is to take partial derivatives of the function with respect to each variable and then combine the errors in quadrature.
Say you have ##f(a,b,c)## with ##a ± Δa##, ##b ± Δb##, and ##c ± Δc##. Then the total error is given by:
$$Δf = \sqrt{\left(\frac{\partial f}{\partial a}\right)^2 Δa^2 + \left(\frac{\partial f}{\partial b}\right)^2 Δb^2 + \left(\frac{\partial f}{\partial c}\right)^2 Δc^2 }$$
Do you remember how to differentiate the log function?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
16K
